Strange HSEROUT behaviour
Results 1 to 11 of 11
    New Jersey
    I experienced something similiar but not sure if it is the same issue as yours. I found that I needed to put a pause statement of 20 milliseconds right after the HSEROUT. I am using this wirelessly and I thought this was the reason. I'm just curious, can you try different pause lengths right after the HSEROUT and let me know what you see?
    Chris
    Sep 2005
    Campbell, CA
    Putting in a PAUSE that is as long as the time it takes to send the string does cure the problem, but my goal is to really understand what PBP is doing.
    I have what may be the "worlds largest PBP Program" (My 8722 is nearly full), and now I'm adding SNMP protocol and another layer of interrupts (assembler). I'm noticing some weird behavior, and I'm trying to understand what is going on.
    Charles Linquist
    END places the PIC in a tight loop executing SLEEP continuously.
    With HSEROUT, PBP loads the outbound character, then issues a call to the
    HSEROUT sub-routine. It doesn't wait for the last character to be sent.
    Program execution returns to the next statement right after the call to
    HSEROUT, lands on SLEEP, kills the CPU clock, and your last character is
    never sent.
    Here's how it works;
        HSEROUT ["AB"]
    Which produces this in assembler;
     0000                GOTO INIT
       0001  HSEROUT       CLRWDT
       0002                BTFSS PIR1, 0x4
       0003                GOTO HSEROUT
       0004                MOVWF TXREG
       0005                BSF STATUS, 0
       0006                GOTO DONE
       0007  DONE          BCF STATUS, 0x7
       0008                BCF STATUS, 0x6
       0009                BCF STATUS, 0x5
       000A                CLRWDT
       000B  DONERET       RETURN
       000C  INIT          BSF STATUS, 0x5
       000D                MOVLW 0x19
       000E                MOVWF TXREG
       000F                MOVLW 0x20
       0010                MOVWF RCSTA
       0011                BCF STATUS, 0x5
       0012                MOVLW 0x90
       0013                MOVWF RCSTA
       0014  MAIN          MOVLW 0x41 ; <-- load 1st character
       0015                CLRF PCLATH
       0016                CALL HSEROUT ; <-- send it
       0017                MOVLW 0x42    ; load 2nd character
       0018                CLRF PCLATH
       0019                CALL HSEROUT ; <-- send 2nd character
       001A                SLEEP <-- goes to sleep before 2nd character is sent
    The PIC is executing instructions a lot faster than your 8-bit serial data can
    be shifted out, so it returns and lands on the SLEEP instruction long before
    data can be sent.
    You need a pause after HSEROUT for a period of at least 1/baud rate*10 or
    loop until the TX buffer flag indicates the last char has been sent.
    -Bruce
    tech at rentron.com
    http://www.rentron.com
    Sep 2005
    Campbell, CA
    Thanks, Bruce!
    That is exactly the type of explanation that I was looking for.
    Going back to my original question, I find that my ISR "kills" HSEROUT.
    Is there some reason why this would happen?
    As I mentioned, I'm saving and restoring W,STATUS,BSR, and FSR.
    Charles Linquist
    What's causing it to crash could be several things, but it's impossible to tell
    without seeing all of your code.
    How often are your interrupts? What happens in your interrupt handler?
    -Bruce
    tech at rentron.com
    what happen if...
    Disable
    HSEROUT ["Your String"]
    WHILE TXREG : WEND
    Enable
    Now how about
    HSEROUT ["YourString"]
    WHILE TXREG : WEND
    Sep 2005
    Campbell, CA
    This is on a 1 millisecond interrupt. Chip is 18F8722
    Here is a portion of the code...
    Asm
    IntHandler
    movwf wsave
    swapf STATUS,W
    clrf STATUS
    movwf ssave
    movf PCLATH,W
    movwf psave
    movf FSR0,W
    movwf fsave
    movlw 0xEC ; Reload TMR0 with 65535 - 5000
    movwf TMR0H
    movlw 0x77
    movwf TMR0L
    btfsc PIR1,5
    goto KeyHit
    bcf INTCON,2 ; Clear the interrupt flag
    infsnz _MasterClock
    incf _MasterClock + 1
    movlw 0x03
    cpfseq _MasterClock + 1
    goto FanRoutine
    movlw 0xE8
    cpfseq _MasterClock
    goto FanRoutine
    clrf _MasterClock
    clrf _MasterClock + 1
    bsf _TPE
    goto DoneForNow
    FanRoutine
    movf PORTB,0,0
    movwf _Temp,0
    xorwf _OldPortB,0,0
    movwf _changedB,0
    movff _Temp,_OldPortB
    Fan1
    btfss _changedB,0
    goto DoneForNow
    infsnz _Fan1Counter
    incf _Fan1Counter+1
    KeyHit
    bsf _KeyHitFlag
    bcf PIR1,5
    DoneForNow
    movf psave,W
    movwf PCLATH
    movf fsave,W
    movwf FSR0
    swapf ssave, W
    movwf STATUS
    swapf wsave, F
    swapf wsave, W
    bsf INTCON,7 ; Turn Global interrupts on
    bsf INTCON,6 ; Turn Peripheral Interrupts on
    retfie ; Return from the interrupt
    EndAsm
    Charles Linquist
  1. I2C Slave with a PIC
    By ralfmayr in forum mel PIC BASIC Pro
    Last Post: - 21st August 2016, 18:44
  2. HSEROUT and Commas, What? Help Me Understand
    By altech6983 in forum mel PIC BASIC Pro
    Last Post: - 20th July 2009, 20:12
  3. Is HSEROUT corrupting bit 7 ?????
    By Robert Wells in forum mel PIC BASIC Pro
    Last Post: - 23rd October 2008, 17:26
  4. Strange behaviour from PIC16F877 on TMR0
    By mikebar in forum mel PIC BASIC Pro
    Last Post: - 19th August 2006, 02:31
  5. Strange HSEROUT execution times
    By SteveB in forum mel PIC BASIC Pro
    Last Post: - 21st May 2006, 19:34
