Student Project
Results 1 to 9 of 9
Thread: Student Project
    aggie's Avatar
    aggie Guest
    Default Student Project
    I am a student at Texas A&M University, and am working with PICs for the first time. I need to use PICS to communicate via an RF Module, so that we can transmit some data.
    Any help is greatly appreciated.
    I have PIC 18F4520.
    Welcome on the forum!
    SERIN
    SEROUT
    SERIN2
    SEROUT2
    HSERIN
    HSEROUT
    are the PBP statement you should use and learn.
    Manchester encoding is another thing you should read about on ths forum.
    There's a ton of Serial comm here and there... worth a few minutes of search and reading.
    http://www.picbasic.co.uk/forum/search.php
    Good luck!
    aggie's Avatar
    aggie Guest
    Thank you for your help. I will look into these
    aggie's Avatar
    aggie Guest
    Could you maybe explain more about the qualifiers it requires in the SERIN command? Is it looking for an address? Suppose I use SERIN like this :
    SERIN PORTC.0, T2400, {[1100]}{X, Y}
    Is that a valid SERIN Command? What would SEROUT look like so it recieves the right data from the other PIC through RF?
    yourmomOS's Avatar
    yourmomOS Guest
    Smile something Im working on for you to play with
    Hi, Ive been working on this serial code that will accept bytes into the uart. it uses a different chip, the 16f628, but it uses circular buffers, an interrupt, and a start and a stop character. If you find anything wrong with it, let me know, I havent fully tested it yet but this should get you started.
    '* Name : bufferdesign.BAS *
    '* Author : David Kinsler *
    '* Notice : Copyright (c) 2006 *
    '* : All Rights Reserved *
    '* Date : 7/6/2006 *
    '* Version : 1.1 *
    '* Notes : BUFFER with interrupt v1.1 w/ buffer overrun *
    '* : resetting AND no endfound variable *
    'Defines area
    'set OSC freq
    Define OSC 20
    ' Set receive register to receiver enabled
    DEFINE HSER_RCSTA 90h
    ' Set transmit register to transmitter enabled
    DEFINE HSER_TXSTA 20h
    ' Set baud rate
    DEFINE HSER_BAUD 9600
    'clear flag automatically when serial hardware buffer overflows
    DEFINE HSER_CLROERR 1
    INTCON.7 = 1 ' Enable Global Interrupt Handler
    INTCON.6 = 1 ' Enable USART Receive Interrupt
    PIE1.5 = 1
    pause 100 'safe startup time
    on interrupt goto INTERRUPTROUTINE
    ENABLE
    'Declare variables and counters
    commandsize con 10
    serbuffsize con 10
    BuffSize con 30 'buffer size
    Buffer var byte[BuffSize] 'buffer array
    SerBuff var byte[serbuffsize] 'used in interrupt to catch incomming data
    StChr con "$" 'determines beginning of command
    EndChr con "^" 'determines end of command
    FirstChr var byte 'holds position of first character in buffer
    LastChr var byte 'holds position of last character in buffer
    FirstSrlChrPos var byte 'holds position of first serial character
    LastSrlChrPos var byte 'holds positon of last serial character
    StartFound var bit 'boolean for testing if stchr found
    Chr Var Byte 'holds inbound character
    Temp var byte[commandsize]
    i var word 'counter for blinking led's
    x var byte
    y var byte 'used to store index of temp
    'EndFound var byte 'found the end of the command String?
    SrlReceived var bit 'bit says weather this is something in serial buffer or not to transfer
    'Initialize variables and counters
    FirstChr = 0
    LastChr = 0
    FirstSrlChrPos = 0
    LastSrlChrPos = 0
    StartFound = 0
    SrlReceived = 0
    'endfound = 0
    x = 0
    y = 0
    MAIN:
    'do something to like blink and led
    high PORTB.4
    for i = 0 to 1000
    PAUSE 1
    NEXT I
    LOW PORTB.4
    FOR I = 0 TO 1000
    PaUSE 1
    NEXT I
    If SrlReceived = 1 Then
    gosub TRANSFERBUFFER
    gosub FINDCOMMAND
    GOTO MAIN
    DISABLE 'disables interrupt
    INTERRUPTROUTINE:
    Hserin [SerBuff[LastSrlChrPos]]
    hserout [serBuff[lastsrlchrpos]]
    'when the SerBuff is read into the larger array later, you increment FirstSrlChrPos
    'as you read it
    lastSrlChrPos = lastSrlChrPos + 1 'increment last character received position
    If LastSrlChrPos = serbuffsize then 'if position = serbuffsize after inc, then position = 0
    LastSrlChrPos = 0 'making a circular buffer, this also insures FirstSrlChrPos
    If LastSrlChrPos = FirstSrlChrPos then
    'SERBUFF BUFFER OVERUN, reset serial buffer data
    HSEROUT ["Serial Buffer overrun, clearing serial buffer", 10]
    LastSrlChrPos = 0
    FirstSrlChrpos = 0
    srlreceived = 0
    goto SRLBUFFOVERRUN
    SrlReceived = 1 'new data in serial buffer
    SRLBUFFOVERRUN:
    Resume 'resumes where left off
    ENABLE 'reneables the interrupt
    TRANSFERBUFFER:
    while FirstSrlChrPOS <> LastSrlChrPos 'while not equal, buffer has not been totaly read.
    Buffer[LastChr] = SerBuff[FirstSrlChrPOS]
    LastChr = LastChr + 1 'FirstChr is incremented in the PROCESSCOMMAND routine
    if LastChr = buffsize then
    LastChr = 0
    disable 'makes sure interrupt can not change lastchr while clearing
    If LastChr = FirstChr Then
    'DO SOMETHING ABOUT BUFFER OVERRUN : ADD CODE HERE
    HSEROUT ["Transfer Buffer overrun, clearing transfer buffer", 10, 13]
    FirstChr = 0
    LastChr = 0
    goto ENDEDTRANFER
    enable 'turns interrupt back on
    FirstSrlChrPos = FirstSrlChrPos + 1 'inc serial buffer start Position
    if FirstSrlChrPos = serbuffsize then 'if its 10, cycle it back to 0
    FirstSrlChrPos = 0 'this creates a circular buffer
    wend
    ENDEDTRANSFER:
    SrlReceived = 0 'all data read from serial buffer
    RETURN 'go back to gosub in main
    FINDCOMMAND:
    'find the start character in buffer
    If Buffer[FirstChr] <> StChr then
    while FirstChr <> LastChr And StartFound = 0
    If Buffer[FirstChr] = StChr then
    x = FirstChr
    TEmp[0] = Buffer[x]
    y = 1
    StartFound = 1
    FirstChr = FirstChr + 1
    if FirstChr = 30 then
    FirstChr = 0
    wend
    if startfound = 0 then
    x = firstChr
    startfound = 1
    'we have now found the start character, do not advance firstchr until you
    'have the whole thing in the temp variable
    While X <> LastChr 'you have not already found the end of the command
    if x <> FirstChr and Buffer[x] = StChr then
    'MISSED COMMAND AND NEW ONE SENT!!!!!!!!!!!!!!!!!
    'START NEW COMMAND AT THIS POINT
    FirstChr = x
    y = 0
    startfound = 1
    Temp[y] = Buffer[x] 'read next character into temp
    if Buffer[x] = EndChr then
    goto PROCESSCOMMAND 'Whole command found, goto process it
    else 'keep counting
    y = y + 1 'inc y for temp
    X = x + 1
    If x = 30 then
    x = 0
    wend
    'eNDFOUND = 0 'BREAK out of while after end is found and reset endfound
    PROCESSCOMMAND:
    hserout [10, 13, "RECEIVED COMMAND: ", STR temp\y + 1, 10, 13]
    FirstChr = x + 1 'remove found commmand from the buffer
    FirstChr = 0
    y = 0
    x = 0 'remove the temp counter
    startfound = 0 'reset startfound
    yourmomOS's Avatar
    yourmomOS Guest
    Talking ALSO - zigbee wireless modules word great
    aggie,
    Forgot to mention that the xbee and xbee pro rf zigbee modules from www.maxstream.net work great. They will communicate right out of the box and allow for different kinds of network configurations. The only problem with them is they require a 2.8 to 3.3 Volt power supply which is hard to come by unless you use variable regulator which requires extra parts.
    Cheers!
    BA33BC0T easy to find 3.3 volt voltage regulator, 1 amp, LDO. Often use here, no problem, close to be cheap to. Don't need to mess with any external resistor, make life easy.. there's tons of other too.
    Microchip do some too... worth to surf in most major parts provider website.
    yourmomOS's Avatar
    yourmomOS Guest
    Default That works, sort of!
    Quote Originally Posted by mister_e
    M_E, I looked all over the place like digikey and jameco and there search engine wouldnt show me these but they do sell them. As for the model, the BA30BC0t looks like the best choice. The xbee's work better on a straight 3v supply. The sleep power increases exponentially it looks like with ever .1 volt above that. Unfortunaly, I just ordered like twenty 317T's not knowing these existed.
    hehe, anyways, how many here can really say that he/she know all component in the whole world... i guess there's at least one new each day... DARRGH hard to be up-to-date
    Last Post: - 8th March 2010, 21:58
  2. A Temperature & Humidity Data Recorder Project
    Last Post: - 9th July 2008, 19:47
  3. Student Final Project Need help
    By marco in forum mel PIC BASIC Pro
    Last Post: - 28th March 2007, 19:12
  4. A category for Project Ideas
    By Pic_User in forum Forum Requests
    Last Post: - 23rd June 2006, 08:29
  5. finall project
    By Mostafa in forum General
    Last Post: - 14th January 2006, 17:38
