PIC18F452 and problem with if statement
Results 1 to 4 of 4
    Talking Something stupid with input ranges ... and Compiler.
    Did you remember PbP " classic " number input and output range is 0 - 65535 ( 16 Bits ) ??? for negative values you could use ABS () care your number do not exceed 15 bits. see manual for explanation.
    Multiple IF Then s ... can be replaced by the SELECT CASE command ...
    Note that's an answer for PBP using !!! I think you're not exactly using PBP ... so, may be you're not on the bestForum to get the right answer ...
    Alain is right. I guess you use PROTON.
    It remind me something so far... if you set the Watchdog timer you may have to use
    WATCHDOG = 0
    But i can be wrong to, i saw few new update for that one so, if you're using the latest upgrade, it shouldnt, hum hum, give you some problem. Anyways i've never use that one too long to have great solution.
    The best place for you is bellow
    www.picbasic.org/forum
    Stephan P.'s Avatar
    Stephan P. Guest
    Yes i am using proton, sorry for that. Go to the other forum.
    THX Stephan
  1. problem whit pic18f452
    By ocastrillo in forum General
    Last Post: - 9th March 2007, 17:18
  2. PIC18F got some weird problem?
    By NatureTech in forum mel PIC BASIC Pro
    Last Post: - 19th February 2007, 17:18
  3. PIC18F452 Compile Problem
    By scottl in forum mel PIC BASIC Pro
    Last Post: - 21st October 2006, 11:47
  4. Replies: 5
    Last Post: - 26th March 2006, 20:26
  5. interupt & Sleep Problem - HELP!!
    By Santana in forum mel PIC BASIC Pro
    Last Post: - 23rd November 2004, 11:39
