I2cwrite - I2cread
Results 1 to 9 of 9
    that will be far easier if you tell us wich PLL you're using
    Jun 2006
    Quote Originally Posted by mister_e
    PIC16F84A AND TSA5511
    refering to table 2 of the datasheet
    IF LOCK.6=1 then
        LCDOUT $FE,1,"PLL in-lock"
    Jun 2006
    IF LOCK.6=1 then
    Thank you , it's work but show continues.
    I want to show on first line of lcd after the frequency
    like this : 100.3 MHZ LOCK
    and if not lock to show
    like this : 100.3 MHZ UNLOCK
    PBP manual, LCDOUT section
    LCDOUT $FE,1,your frequency plah plah,"MHZ "
    IF LOCK.6=1 then
        LCDOUT "Lock  "
            LCDOUT "Unlock"
    Jun 2006
    IF LOCK.6=1 then
        LCDOUT "Lock  "
            LCDOUT "Unlock"
    Thank you
    I write this code and work:
    LCDOUT $FE, 1 'Clear LCD screen
    LCDOUT #F2 'post the other digits
    LCDOUT "." 'post the comma
    LCDOUT #F3 'post the Khz
    LCDOUT " MHz "
    IF LOCK.6=1 then
    LCDOUT "LOCK"
    LCDOUT "UNLOCK"
    LCDOUT $FE,$C0
    LCDOUT "PLL FM 87.5-108 "
    But i want the word LOCK or UNLOCK to begin at 13th position
    I try this LCDOUT $FE, $80 +13
    but it's not work
    odd... it's working here..
    LCDOUT $FE,($80+13),"lock"
  1. I2CRead & I2CWrite not working as expected
    Last Post: - 27th October 2021, 18:36
  2. Problem with I2Cread and I2CWRITE function
    By Tony85 in forum mel PIC BASIC Pro
    Last Post: - 6th June 2006, 20:03
  3. Problem with I2Cread and I2CWRITE function
    Last Post: - 6th June 2006, 18:32
  4. PFC8583 Connection and I2Cwrite I2cread!
    By uludere72 in forum mel PIC BASIC Pro
    Last Post: - 27th February 2006, 13:32
  5. I2CWRITE and I2CREAD
    By Tomas in forum mel PIC BASIC Pro
    Last Post: - 23rd April 2004, 02:30
