Using MPLAB SIM
Results 1 to 5 of 5
Thread: Using MPLAB SIM
    Sep 2005
    Campbell, CA
    Default Using MPLAB SIM
    Does anyone have any experience using MPLAB SIM on the output from PBP? Could you please give a very short explanation about how to go about using it?
    Charles Linquist
    Hi Charles,
    I use MPLAB/MPSIM all the time with PBP. In your PBP installation directory
    there's a text file mplab.txt that explains how to setup & use PBP with MPSIM.
    If you have specific questions let me know.
    -Bruce
    tech at rentron.com
    http://www.rentron.com
    Sep 2005
    Campbell, CA
    OK. I got everything loaded. I did a compile from within MPLAB. So far, so good. I clicked on the "source files" tab, and my .BAS program appeared in the window. In the Project Tree on the left there were no "Other files".
    I brought up the "Special Function Registers" and the "Program Memory" with the appropriate tabs. One line in the Program Memory window had a green arrow by it.
    I pressed the RUN button, and I got a moving bar on the bottom left that stated that something was "Running".
    But nothing moved. No pointers moved, no registers updated. Nothing.
    What am I doing wrong?
    Charles Linquist
    If you want to watch things happen, use the Animate button.
    -Bruce
    tech at rentron.com
    Sep 2005
    Campbell, CA
    That works ! Thanks !
    Charles Linquist
  1. MPLAB SIM timing vs Real life
    By Bronurstomp in forum mel PIC BASIC Pro
    Last Post: - 17th July 2008, 17:32
  2. MPLab SIM question
    By presario1425 in forum mel PIC BASIC Pro
    Last Post: - 3rd December 2007, 22:22
  3. Linker/COFF debugging in MPLAB SIM
    By RichardBowser in forum mel PIC BASIC Pro
    Last Post: - 14th January 2007, 19:28
  4. Tracing code in MPLAB Sim
    By ErnieM in forum mel PIC BASIC Pro
    Last Post: - 8th August 2005, 17:00
  5. pause loop lockup with mplab sim
    By power67 in forum mel PIC BASIC Pro
    Last Post: - 12th February 2005, 14:10
