accessing source code
Results 1 to 2 of 2
    mle's Avatar
    mle Guest
    Default accessing source code
    Hello,
    Is there a way of accessing the code for built in functions? In particular HSerout().
    Thanks, Emily
    You can see what code HSEROUT contains by looking inside your libraries... typically open PBPPIC14.LIB and search for HSEROUT. If you're brave you can even modify and create your own variants.
    However if you need to do something clever, Hardware Serial Output is particularly easy from within PBP without needing to use HSEROUT. Just look at the ASYNC section of your chosen PIC's Datasheet and you get all the information you need listed step by step... For example 16F628, section 12.2 look for the numbered step-by-step guide at the end of that section.
    Melanie
  1. How much code space do PBP statements use.
    Last Post: - 13th February 2009, 22:31
  2. Loop with two motor and 2 sensors
  3. Replies: 1
    Last Post: - 21st February 2008, 16:36
  4. Please help ? RF Remote Source code
    By sorasit46 in forum mel PIC BASIC Pro
    Last Post: - 25th April 2007, 15:40
  5. Replies: 0
    Last Post: - 15th December 2006, 20:16
