252 or 2520
Results 1 to 11 of 11
Thread: 252 or 2520
    pretty close price or not is not revealant on a single of few device. But when you do a project and create 100 000 or million of them... few cents of difference made enough difference to be considered.
    Uneless you use the PBP I2CREAD/I2CWRITE, you shouldn't experiment any problem because it doesn't use the PIC MSSP... it's a simple software solution who handle everything for you on the i/o you want to use for your I2C bus.
    Now wich one trust? I can't say, but before, be sure of they do all you need, be sure that a lower model wouldn't fit, and so on. If it was me to decide, i would check to some other wich have less errata. But it's just me, i prefer to leave possible problem to other. I have those in stock now in case of, but i've never messed with them.
    I admit that i'm kinda addictive to those pinned black box
    Yes, I use I2C, but PBP's I2CREAD and I2CWRITE and not the chips hardware module. Everything is fine as mister_e suggested. I also use internal EEPROM READ/WRITE also from PBP on this chip, again no problems with that either. The Timers work too and so do the ADC's and the pwm modules as I mentioned earlier. But on the negative side, I can't vouch for any hardware components I've not listed. The Labour and Parts saving in not having to add a Resonator or Xtal is worth the the few cents extra. I have about 100/day of the 18F2420 (and the LF version when earlier we couldn't get stock of the straight one) going into the field, with the first units being shipped at the start of the year - nothing's bounced back. This is a major product badged for a blue-chip company that earns me big-bucks in royalties, I wouldn't risk that on a suspect PIC.
    icaotyr's Avatar
    icaotyr Guest
    Default problems with i2c
    Im trying to communicate with i2c two Picīs a master and a slave of course. I attemp to do a communication with 3 slaves later but at first i have to do it with a single one. Im having problems initiating the i2c protocol.
    Im using MPLAB to create the master and slave code. Using MPSIM and checking the ssp registers i see that the code is right in theory but once i try it on the chip it doesnt work. I cant initiate the Start condition i activate the SSPEN flag in SSPCON2 in the simulation it works pefectly but in the chip polling the register i can see that the flag have never been set i dont know which problem i have but please i need some help
