midi sysex
Results 1 to 7 of 7
Thread: midi sysex
    knsj's Avatar
    knsj Guest
    Talking midi sysex
    I was wondering if pic basic is the way to go
    I not only need to send midi notes but also midi sysex F0 7F 0 6 4 F7
    to a device can this be done
    As far as i'm aware of, if you can acheive the needed baudrate, there's no problem. Just do a google search and you'll find all the info you need. You may also found some PicBasic code.. no surprise if so.
    knsj's Avatar
    knsj Guest
    Talking midi sysex
    can anyone give me an example of this or lead me in the right direction
    thanks so much i did a search but only sending midi notes came up
    not sysexc (info to change hardware config like bank , program , dump or load., in this case i am trying to control a mackie harddisk recorder
    thanks so much .,
    Quote Originally Posted by mister_e
    it shouldn't be as this much different. Look in your Mackie manual, MIDI command have to be listed. If not, ask Mackie. As i know them, they will send you the info you need. They don't provide the best quality product (but the best quality/price ratio), but have a great support for most of their Pro Equipement.
    Tell me wich Mackie unit you have. I do business with the local Mackie distributor/service center here.
    knsj's Avatar
    knsj Guest
    Talking sysex
    thanks again for your help i have a SDR24 harddisk recorder
    it works great but the controller is no longer sold. so i need to make my own.
    thanks so much ., knsj
    i've heard that some distributor may still have the MicroRemote Controller
    http://www.mackie.com/products/home/...tributors.html
    knsj's Avatar
    knsj Guest
    Talking re: remote
    I have found a few on ebay but $$$$$$$$$ is way up there
    so if i could i would rather make my own .,
    so i can add features not on the remote 24 .,
    thanks 4 your help ., knsj
  1. SERIN MIDI out of Synch?
    By jncortes in forum mel PIC BASIC Pro
    Last Post: - 9th June 2009, 21:08
  2. How to HSERIN and MIDI code?
    By francolok in forum Serial
    Last Post: - 18th December 2008, 17:59
  3. Midi, Interrupts and Pic better than SX28?
    By Lajko in forum mel PIC BASIC Pro
    Last Post: - 27th September 2008, 01:26
  4. 12f675 and midi!
    By Alaskanphoenix in forum mel PIC BASIC Pro
    Last Post: - 14th April 2006, 17:25
  5. SMPTE to MIdi
    By loredana in forum mel PIC BASIC Pro
    Last Post: - 26th July 2005, 00:33
