Button
Results 1 to 11 of 11
Thread: Button
    Jun 2006
    Default Button
    a)how i can to go fast when push the button of below code:
    Button UP,1,10,2,b1,1,MONTE ' button UP
    Button DOWN,1,10,2,b2,1,DESCEND 'button DOWN
    b)how i can to write this code which is for 50
    F3=50*(F1//16) 'this work
    to make for 62,5 , like this :
    F3=62,5*(F1//16) 'this don't work
    Feb 2003
    Salt Lake City, Utah USA
    Smile
    a) not clear to me what you want??
    b)
    PBP supports integers only...
    try
    F3=125*(F1//16)/2
    or
    F3=(125*(F1//16))>>2
    check your answers to make sure you can live with the roundoff (e.g., if F1=17 then F3 will be 62 not 62,5.)
    Paul Borgmeier
    USA
    50? Msec, Microsecond? hours? Days? Is this the rate, the debounce or what? if so, as i remind of button 'cause i don't use it, you can tackle 'round some DEFINE.
    Jun 2006
    Quote Originally Posted by paul borgmeier
    b)
    try
    F3=125*(F1//16)/2
    or
    Paul Borgmeier
    USA
    i change the code:
    ' ** CALCULATION OF THE FREQUENCY
    F1=PLL
    F2=F1/16 'give them MHz
    F3=125*(F1//16)/2 'give them kHz
    and it's work.
    Only have one problem . All frecuencies-step show corect(125,250,500,1000), but the 62,5 show only 62
    i.e. for PLL FM ,62,5KHZ is the step.when i choose 62,5 show on LCD 62 ,while i choose 125,250,500,1000 show corect
    multiply by 10 or get the remainder with R2 predefined variable
    http://www.picbasic.co.uk/forum/show...ight=remainder
    Jun 2006
    Quote Originally Posted by savnik
    When push the button Up the frequency of PLL go to up with the same rhythm.Iwant to change the code so when push the button Up the frequency of PLL to increase little by little.
    Sorry for my bad english.
    When you say you want to change PLL frequency.. is it the PIC one or an external one?
    arrete de t'en faire pour ton anglais.. il y a pire que ca
    Jun 2006
    Quote Originally Posted by mister_e
    I can change the frequency.
    I want as long as push the button to change the speed .In the beginning is slow and to go fast as push the button.
    Jun 2006
    any help ;
    Apr 2006
    New Hampshire USA
    Smile Helping with the meaning.
    I want as long as push the button to change the speed .In the beginning is slow and to go fast as push the button.;
    You would like:
    When you press the "up button" the frequency increases a certain amount, a "step".
    If you hold the "up button" in, the frequency increases, by small amounts, "steps", slowly.
    If you continue holding the "up button" in, the frequency increases, by larger amounts, faster.
    Of course, the same with the "down button".
    Like setting the time on some clocks.
    Hold the button and the clock changes faster as the button is held down.
    Question:
    When holding the button.
    Would you want the SIZE of the steps to increase, or the SPEED of selections to increase?
    -Adam-
    Jun 2006
    Quote Originally Posted by Pic_User
    Question:
    The first
  1. Sony SIRC IR Issue
    By Ryan7777 in forum mel PIC BASIC Pro
    Last Post: - 8th August 2015, 09:10
  2. 3 HPWM channels
    Last Post: - 4th April 2006, 03:43
  3. Code check -- button not working
    Last Post: - 2nd March 2006, 23:43
  4. Button Push within 3 second Window
    Last Post: - 22nd December 2005, 11:06
  5. Button subfunction 16F628
    By Jųan in forum mel PIC BASIC Pro
    Last Post: - 19th August 2005, 17:44
