square to sine wave help
Results 1 to 7 of 7
    TONIGALEA's Avatar
    TONIGALEA Guest
    Default square to sine wave help
    Hi Everyone
    Please do anyone have a simple circuit that would take
    an input square wave 50/50 and output a sine wave.
    the range would be between 1 to 2 khz
    Any pointers would be very much appreciated
    Toni
    bot402's Avatar
    bot402 Guest
    First convert the square wave into a triangle wave, then round the edges of the triangle wave.
    A search on Google should give you plenty of circuits for square to sine, square to triangle, and triangle to sine.
    That's what we call an integrator. Integrate 2 time should works good. more than 2 time work better. It depend of the distortion % you want live with.
    at the end you'll probably need to amplify the gain du to the loss in the filtering/integration process.
    a Quad Op-Amp TL074,TL084 or a dusty LM324 should works great for that frequency range.
    brighton
    Thumbs up Still not solved
    Thanks for all your replies but i still find it difficult to find a circuit that
    would do the conversion from square to sine wave so i am going to use
    two wien bridge oscillators to generate the 2 different audio sine waves
    that i need and use an analogue switch to select the the individual oscillator
    if anyone has done square wave to sine using op amps i would be glad to
    to hear from you
    Best Regards
    Isaac
    Jun 2005
    Mumbai,India
    Post Sinewave
    I checked these links and found to be very preliminary.
    U should check the National Semiconductor's Opamp Circuits Application
    note. If Ur input frequency is fixed then use Bandpass filter -Besel or Chebishev type tuned to that frequncy as centre of bandpass.With LM324
    U can do upto 2-300Hz but with TLO64 or better U can go to 10Khz. With
    the quad opamp U can make 2stage filter with very low distortion.U may
    need additional gain stage for final output.
  1. To Generate Sine Wave Using PCPWM of PIC18F4331 (Issue)
    By Cyborg in forum mel PIC BASIC Pro
    Last Post: - 22nd March 2014, 14:39
  2. Sine wave
    By Darrenmac in forum mel PIC BASIC Pro
    Last Post: - 18th May 2009, 04:31
  3. Generating 3-phase sine wave..
    By sirvo in forum mel PIC BASIC Pro
    Last Post: - 6th November 2008, 15:07
  4. Replies: 1
    Last Post: - 16th February 2005, 21:05
  5. PBP Dampened Sine Wave
    By Keith55555 in forum mel PIC BASIC Pro
    Last Post: - 3rd April 2004, 21:01
