Hello Everybody. I need to output 2 PWM's at 15KHZ (approx) simultaneously and control the duty cycles independently. The PBP manual says you can do it on PIC's with more than 1 channel. However, the PIC I want to use is 16F684. According to the datasheet, the PWM module is multiplexed among 4 possible outputs. There was also a note that changing something while the PWM is running will "cause a glitch". Will this PIC work? I need a small PIC with more than 1 PWM and if I can't use the 'F684, do I have to move up to a 28 pin PIC? Thank you.
