they shoot horses
Results 1 to 4 of 4
    Thumbs down they shoot horses
    really up a wall trying to program a 16f877a will not run with any programs
    have one that some else programed works fine only have hex file
    is there a start button cannot get anything to work as simple as blink led
    no lcd no serin nothing
    have checked electrical mclr 1 resistor to +5
    crystal pin 13-14
    power
    ok
    malc-c's Avatar
    malc-c Guest
    I don't thank anyone will be able to help you based on the limited information in your post. You'll need to state things like:
    1) - what hardware programmer are you using.
    2) - what software you use to send the HEX file to the PIC
    3) - details of your hardware, how are you testing the PIC
    4) - details of your PBP code
    Without this sort of info I think most of the suggestions (if any) will be guesses
    Arrow more info
    ok will try for more info
    one question that comes up is the define osc 20 does not seem to work
    built a small prototype with a 4mhz crystal and got blinkie to work
    is there a better statement to insur this works or is my syntax bad
    apreicate the help
    Exclamation added info
    as for as the programmer k149 and it will program the sample chip and it works fine
    hardware is as simple as you can get nothing but power and crystal
    except when i am using it on a factory wired board which works fine with
    the programed chip
    just trying to make changes
