COUNT Function
Results 1 to 3 of 3
Thread: COUNT Function
    Jun 2005
    Default COUNT Function
    Hi everyone, I just wanna know if there's a define to change the COUNT instruction for counting high to low instead of low to high transitions. I know I can simply place a little transistor to invert the signal but if a define can do the trick...
    i don't think so but you can do it in software easily using an internal Timer/Counter. There you'll be able to specify the transition you need
    Sometimes, depending the PIC, it's assign to PORTA.4/T0CKI pin.
    easy to implement and, by far, much code efficient.
    do a search with T0CKI and you should find something 'round here.
    Feb 2003
    Salt Lake City, Utah USA
    Smile
    For every high there has to be a low. If you know the state of your input pin at the beginning and end of the count process, cannot you get high-low counts from the low-high count?
    CountStart = PORTB.3
    Count 3, 1000, W1
    CountEnd = PORTB.3
    Paul Borgmeier
    USA
  1. Single button function
    Last Post: - 4th April 2020, 19:33
  2. Doubling the pusle count
    By malc-c in forum mel PIC BASIC Pro
    Last Post: - 17th May 2012, 14:17
  3. COUNT is not counting again
    Last Post: - 19th June 2009, 05:52
  4. Can't get COUNT to count
    Last Post: - 24th March 2009, 00:14
  5. Count command
    By hawk72501 in forum mel PIC BASIC Pro
    Last Post: - 6th September 2005, 20:04
