Noobie Question
Results 1 to 20 of 20
Thread: Noobie Question
    Feb 2003
    Salt Lake City, Utah USA
    Red face
    Quote Originally Posted by dhouston
    Only if you set the config fuse to disable MCLR and make GPIO.3 an input.
    For clarity, I guess I should have added the bold to my original comment so that it read
    "if GP3 is set as MCLR internal you have no choice since it is auto configured as an input, which is what you want."
    With Steve's discussion above and before mine, I thought this was clear but after rereading my response this morning, I see that it was not - good catch.
    Paul
    Dec 2005
    Paul,
    It gets confusing because all of the various programmers use different terminology to refer to the MCLR config setting so it's hard to create a universal "how to".
    and more, pretty bad that PBC don't allow to set the config fuses in the code.. that would be so much convenient. Yet another real limitation of PBC.
        @ __CONFIG _INTRC_OSC_NOCLKOUT & _WDT_ON & _PWRTE_ON & _MCLRE_OFF & _BODEN_ON
             ' Internal Oscillator
             ' Enable watch dog timer
             ' Enable power up timer
             ' Disable MCLR pin
             ' Enable brown out detect
    Feb 2003
    Smile
    Quote Originally Posted by mister_e
             ' Disable MCLR pin
    Without PBC, I cannot test or look at the "supplied" files but if the fuses are not dropped in by a .inc file like they are in PBP, I wonder if the user could include them in the following manner (at the top of their program):
    device pic12F675, intrc_osc_noclkout, wdt_off, mclr_0ff, protect_off
    I do remember that PBC supports inline ASM – shouldn't this work?.
    (I use MPASM - I am not sure if the format for PM is correct above).
    If it does work, I think this would be easier than having to edit the .inc file like we do in PBP. Thoughts?
    Paul Borgmeier
    USA
    Dec 2005
    Quote Originally Posted by paul borgmeier
    I don't think it will work because the programmer does not look at the file. The fuses have to be set by the programmer. With PBP and the MEL programmer, the @device statements are read by the programmer and it, in turn, sets the fuses.
    Feb 2003
    I must be from Missouri because I still do not see why it will not work. When I write in pure ASM, I include the __Config in my ASM file and MPLAB takes care of my fuses. When I write in PBP, I edit the inc. file for my fuse choice and the fuses are set by MPLAB.
    I have not used PM or the EPIC for years but doesn't one, when using PBP with these two, edit the .inc file for the proper device settings and then the fuse settings are automatically set when programming?
    I have PBC somewhere and an old EPIC somewhere – maybe I need to see it not work to believe it. (I hope I can find them).
    Paul
    Dec 2005
    You can refer to Melanies post for how to set config fuses with PBP depending on whether you use PM or MPLAB.The Epic Windows software will read the file and, if you have this option enabled, set the config items.
    With PBC you will get a compiler error at @.
  1. Extreme Noobie question 12F675
    By Jeff in forum mel PIC BASIC
    Last Post: - 22nd September 2009, 02:13
  2. noobie to PICs and PBPro... Programming question.
    By mcphill in forum mel PIC BASIC Pro
    Last Post: - 25th October 2007, 19:35
  3. noobie question
    By 02GF74 in forum General
    Last Post: - 29th November 2006, 19:47
  4. Question for a math guru
    Last Post: - 22nd November 2006, 10:45
  5. Please answer my first question
    By John_001 in forum Off Topic
    Last Post: - 15th September 2006, 07:49
