Only if you set the config fuse to disable MCLR and make GPIO.3 an input.Originally Posted by paul borgmeier
For clarity, I guess I should have added the bold to my original comment so that it readOriginally Posted by dhouston
"if GP3 is set as MCLR internal you have no choice since it is auto configured as an input, which is what you want."
With Steve's discussion above and before mine, I thought this was clear but after rereading my response this morning, I see that it was not - good catch.
Paul
Paul,
It gets confusing because all of the various programmers use different terminology to refer to the MCLR config setting so it's hard to create a universal "how to".
and more, pretty bad that PBC don't allow to set the config fuses in the code.. that would be so much convenient. Yet another real limitation of PBC.
Code:@ __CONFIG _INTRC_OSC_NOCLKOUT & _WDT_ON & _PWRTE_ON & _MCLRE_OFF & _BODEN_ON ' Internal Oscillator ' Enable watch dog timer ' Enable power up timer ' Disable MCLR pin ' Enable brown out detect
Without PBC, I cannot test or look at the "supplied" files but if the fuses are not dropped in by a .inc file like they are in PBP, I wonder if the user could include them in the following manner (at the top of their program):Originally Posted by mister_e
device pic12F675, intrc_osc_noclkout, wdt_off, mclr_0ff, protect_off
I do remember that PBC supports inline ASM – shouldn't this work?.
(I use MPASM - I am not sure if the format for PM is correct above).
If it does work, I think this would be easier than having to edit the .inc file like we do in PBP. Thoughts?
Paul Borgmeier
Salt Lake City, Utah
USA
I don't think it will work because the programmer does not look at the file. The fuses have to be set by the programmer. With PBP and the MEL programmer, the @device statements are read by the programmer and it, in turn, sets the fuses.Originally Posted by paul borgmeier
I must be from Missouri because I still do not see why it will not work. When I write in pure ASM, I include the __Config in my ASM file and MPLAB takes care of my fuses. When I write in PBP, I edit the inc. file for my fuse choice and the fuses are set by MPLAB.Originally Posted by dhouston
I have not used PM or the EPIC for years but doesn't one, when using PBP with these two, edit the .inc file for the proper device settings and then the fuse settings are automatically set when programming?
I have PBC somewhere and an old EPIC somewhere – maybe I need to see it not work to believe it. (I hope I can find them).
Paul
