glcd with picbaicpro again
Results 1 to 7 of 7
    May 2006
    Default glcd with picbaicpro again
    hello
    who would have a concrete example of use for the glcd ks0108?
    I do not find a code simple to write text with a position defined, on the site: http://www.compsys1.com/workbench/index.html
    thanks
    http://www.compsys1.com/support/PBP_Files/glipic/
    Read all the .BAS file (top comments too) and you should be able to make it work. i know few people 'round here who already used that with success.
    Still no luck, your time is short and can afford the developpement cost of something simple to use like..
    INCLUDE "KS0108GLCDDriver.Bas"
    String1="HelloWorld"
    String2="String2"
    GCLDOut 1,1,String1 ; display on first line, first column
    GLCDOut 2,1,String2 ; display on second line, first column
    drop me off list, i can order one of those GLCD and do the routine for you... i just hope it's not a single ended project uneless it's not going to be the cheapest solution
    I admire the compsys team to do it for free so far...
    May 2006
    thanks for your help
    where find KS0108GLCDDriver.Bas?
    it's not done as this point... it's just an example of how simple it could be if you really want it and can afford the price of it.
    Interested? drop me a message in my Private Message box here.
    May 2006
    I have already a ks0108 with my development board easypic3!
    May 2006
    up
    does nobody have sample?
    Lightbulb Slave module ... simple coding ... serial input.
    Just have a look to Electronique Pratique N° 279 ...page 86 >
    It just needs a F.U.L.L. 16F876@20Mhz .... to say it takes " some room " to drive a 128x64 GLCD.
    Last Post: - 8th March 2010, 21:58
  2. PBP Glcd
    By RICHARD.C in forum mel PIC BASIC Pro
    Last Post: - 13th June 2008, 03:21
  3. GLCD and TouchScreen trouble
    By SteveB in forum Off Topic
    Last Post: - 13th June 2007, 15:11
  4. GLCD and its resolutions.
    By mesamune80 in forum mel PIC BASIC Pro
    Last Post: - 10th January 2007, 15:14
  5. How to put valiable to GLCD
    By pramarn in forum mel PIC BASIC Pro
    Last Post: - 13th October 2006, 17:18
