iButton
Results 1 to 6 of 6
Thread: iButton
    menze's Avatar
    menze Guest
    Question iButton
    Hello. I want to make a simple program that can write some code to a ibutton, then read it again, and then, store it in EEPROM, so I can check that the code has been programed ok. I have already spent a lot of time trying to make it work, but it doesnt. My ibutton is DS1993. Here is the code:
    DEVICE 16F628
    SYMBOL DQ = PORTB.2
    DIM B1 AS BYTE
    DIM HighAddress AS BYTE
    DIM LowAddress AS BYTE
    DIM EndAddress AS BYTE
    DIM ReadIN[32] AS BYTE
    B1 = $23
    HighAddress = $00
    LowAddress = $00
    EndAddress = $0F
    HIGH PORTA.4
    DELAYMS 500
    LOW PORTA.4
    DELAYMS 1000
    OWRITE DQ, 1, [$CC] ' Send Reset & Skip ROM command
    OWRITE DQ, 0, [$0F] ' Send Write scratchpad command
    OWRITE DQ, 0, [HighAddress] ' Send Start address. i.e.(14h)
    OWRITE DQ, 0, [LowAddress] ' Send Start address. i.e.(00h), address=0014h
    OWRITE DQ, 0, [B1,B1,B1,B1,B1,B1,B1,B1] ' Send No reset, 1st 8 bytes
    OWRITE DQ, 0, [B1,B1,B1,B1,B1,B1,B1,B1] ' Send No reset, 2nd 8 bytes
    OWRITE DQ, 0, [B1,B1,B1,B1,B1,B1,B1,B1] ' Send No reset, 3rd 8 bytes
    OWRITE DQ, 2, [B1,B1,B1,B1,B1,B1,B1,B1] ' Send 4th 8 bytes & Reset
    ' Copy Data from scratchpad to page
    OWRITE DQ, 0, [$55] ' Send copy scratchpad command
    OWRITE DQ, 2, [EndAddress] ' Send E/S. (Last address written to) & Reset
    OWRITE DQ, 0, [$F0] ' Send Read memory command
    OREAD DQ, 2, [ STR ReadIN\32 ] ' Read 1st 32 Bytes & Reset
    EWRITE 0, [READIN[0], READIN[1], READIN[2], READIN[3], READIN[4], READIN[5], READIN[6], READIN[7], READIN[8], READIN[9], READIN[10], READIN[11], READIN[12], READIN[13], READIN[14], READIN[15]]
    HIGH PORTA.4
    Thanks.
    Big thread on DS1994 iButton here...
    http://www.picbasic.co.uk/forum/showthread.php?t=250
    It's possible some code may be useful to you...
    but unfortunately, it's not going to be a pure copy/paste solution, you'll have to do some code modification to make it work with the compiler you use
    menze's Avatar
    menze Guest
    Quote Originally Posted by mister_e
    Thanks for all the info. I have no idea how to modiy the code because that code is used to read an ibutton cloik, but i need to read and write all the pages.
    If you have some info, please send it to me.
    Thanks again
    Menze
    well i can't really tell you how about because i no longer use the PROTON compiler as i feel you use just by seeing your variable declaration, the way you write to EEPROM and the DelayMS statement.
    maybe the PROTON forum will be handy for you
    www.picbasic.org/forum
    menze's Avatar
    menze Guest
    Thanks for the info!!!
    Menze
  1. Efficient comparison on data (iButton)
    By enigma in forum mel PIC BASIC Pro
    Last Post: - 27th August 2010, 14:37
  2. Writing & Reading to iButton EEPROM
    By crhomberg in forum Code Examples
    Last Post: - 6th October 2008, 20:40
  3. Dallas IButton 1990 Presence pulse
    Last Post: - 15th August 2008, 23:04
  4. How to calculate CRC16 checksum for iButton
    By ashwini kotwal in forum General
    Last Post: - 17th March 2008, 20:48
  5. DS1920 IButton
    By scottl in forum mel PIC BASIC Pro
    Last Post: - 2nd November 2007, 01:39
