Some questions for programming
Results 1 to 5 of 5
    Mar 2006
    Default Some questions for programming
    I use PBP + MicroCode Studio plus and Picstart+ for 12F675 I should need to know some basic questions concerning the following points of programming:
    1- Is there any advantage to use WDT on? My programs are very linear and I never use Sleep sentences but I realize my compiled files use many times along the program WDToff code. Could be my code more save if I disable WDT at the beginnig of program?
    2- My MCLR is tied to +5 through a 10K resistor without capacitor. When I try ICSP Picstart doesn't permit to do it -GP0 and GP1 are not conected to application circuit- Whats the difference between MCLR internal or external programming? If I set MCLR internal do I need 10k resistor?
    3- If I don't use Power up timer whats the best setting for programming: on or off option?
    -Francesc
    Apr 2005
    This may not answer your question, but something to watch out for on the 12F675.
    Make sure you do not try to use the MCLR pin as an input and use the Internal Oscilator at the same time This does not work for some reason and can make chips useless.
    I have the mclr pin through a diode and then a 10K to 5v with no problems. I have the MCLR set to be used as a reset pin (not input) and the INTOSC on.
    To try to answer your other questions:
    1) the WDT is good to use...if your program locks up for a random reason the WDT will reset the microchip after a period of inactivity. If you are having erratic results with your code you may want to turn the WDT config fuse off while you troubleshoot to make sure the WDT is not causing an issue.
    2)See number above, but to expand I would just always setup the MCLR pin as a reset pin with a 10k and a diode to be safe
    3) If you don't want to use the power on timer, just make sure you set the config fuse to OFF
    Feb 2003
    Salt Lake City, Utah USA
    Smile
    Somebody forgot to tell my 12F675 parts because they all work great in this mode. It appears nobody has told microchip either
    1) Modifyit is right - WDT is good to stop lockups. Because PBP normally does not know if you will set the WDT fuse or not, the code length is the same regardless. If you do not plan to use the WDT and are really squeezed for space, you can insert
    DEFINE NO_CLRWDT 1
    at the beginning of your code for a very modest savings in code space. If you are planning to use sleep commands (which you said you are not), it is better to use the WDT (if you want them to work).
    2)
    No - there is not one in place if you program in the PSP ZIF, not one needed for ICSP. You probably need the diode as suggested my modifyit - it depends on your circuit.
    3) If you set the fuse for Power up timer, you are using it (you have no choice with the fuse set). Setting this bit keeps the processor in reset for 72 mS at power up - see datasheet. I like mine on but it depends on what you are doing.
    Paul Borgmeier
    USA
    Quote Originally Posted by modifyit
    MIIP bad answer, there's no reason, no link between them. I use this setup often and never encounter any kind of problem.
    PicStart is often bad when using in ICSP. Also he's very noise sensitive, so keep wires short, use the 10K+Diode... TADA no problem when doing it. In some case, if you set the weak-pull up it may cause you some erratic boot-up problem... but reset the whole thing will work. This problem doesn't seems to happen with a real ICSP capable programmer like BK Precision 844a (Elnec).
    Go go go, use internal OSC, use MCLR as input but... have some respect to the hardware requirement.
    In some case, PICStart ICSP will work better if you let him power your PIC... yeah it's a pain, close your external PSU, program, then turn on your power supply.... that's annoying but it's working.
    Apr 2005
    I will try and dig up the email I got from PBP support concerning using the MCLR Pin as an Input and the INTOSC at the same time. I fried a bunch of 12F675's trying to do it, and PBP support responeded to my questions saying that it was not recommended on the 12F675.
  1. Two quick (and elementary) questions.
    By scorpion990 in forum mel PIC BASIC Pro
    Last Post: - 27th June 2008, 00:03
  2. A few 12F683 questions
    By dhouston in forum mel PIC BASIC Pro
    Last Post: - 24th May 2008, 04:54
  3. Usart Questions
    By shawn in forum mel PIC BASIC Pro
    Last Post: - 8th March 2008, 02:17
  4. Still new to PicBasic - i2c questions
    By cometboy in forum mel PIC BASIC
    Last Post: - 13th November 2006, 19:27
  5. Hi Everyone! Some newbie questions :-)
    By guest_05 in forum mel PIC BASIC Pro
    Last Post: - 28th October 2006, 23:24
