3-wire LCD interface?
Results 1 to 21 of 21
    atomski's Avatar
    atomski Guest
    Question 3-wire LCD interface?
    Hello everyone,
    here's yet another question, I couldn't
    find info about in the forum archives. How
    would one go about connecting an alpha
    numerical LCD (e.g. 1X16 HD44780) via
    74HC595, 74HC154, CD4094 or similar?
    I'm short of pins and I'd like to build a
    cheap serial LCD using 12C508/509 w/
    3-wire interface to the LCD. Sample source
    code would be appreciated. I'd prefer to
    use 74HC595 as I have an abundance of
    these Serial comm. on 12C508/509 is
    something I've never tried out, but I have
    2 or 3 laying around and I'd like to give it
    a try. Thanks very much in advance...
    Sincerest regards,
    YZ7REA Vladimir M Skrbic
    4N7ATV Repeater Administrator
    YU7GHZ Radio Club President
    Feb 2004
    Germany
    Have you tried the attached ?
    Dec 2003
    Wichita KS
    I posted some code earlier, for a two wire interface.
    You use 2 wires, one for data, and one for clock. It has
    a extremely fast baud rate. (controllable to any speed, but in the 10's of thouasans uncontrolled) If you would like, I will repost
    the code.... I also have designed a single wire interface, to
    where a 12f675 can be used to control a LCD. with one wire.
    I use a 16f648A for the receiver of the data, and controller of the
    LCD. (for both cases). That way, a single 12f675 can control
    5 LCD's at once...separately and the 6th pin of the 675 is the MCLR or input pin.
    Dwayne
    Ability to Fly:
    Pilots that are Flying:
    atomski's Avatar
    atomski Guest
    Guys, thanks for the reply. I have already
    built a serial LCD using 16F628 & MAX232,
    however I'd like to use a cheaper PIC like
    508/509 and one of the mentioned IC's.
    The schematics on the image looks ok, but
    I still don't know how to drive the HC IC
    I've never used 3-wire bus before. As I
    said earlier I would prefer using 74HC595
    as I have tons of these in my drawer. Any
    chance any of you guys could help me out
    with 595 pbp code? Thanks!
    Sincerest regards,
    Feb 2004
    Germany
    @ DWAYNE
    ---> Glass is 1/2 full, not 1/2 emty
    Having thought about it I came to the conclusion:
    The glass is neither ½ full nor ½ empty,
    it is twice as big as it needs to be !
    Dec 2003
    Wichita KS
    Hello NavMicoSystems,
    NMS>>@ DWAYNE
    it is twice as big as it needs to be !<<
    <chuckle> Good one. But I like having that little extra room, just in case I can come out a little more ahead than someone else <g>.
    But, your response reminded me when I shot in the nationals in 2000. I shoot BareBow Olympic Style, and there is was a saying that us BareBow shooters used.
    to explain how it works, a BareBow has no sights, no added mechanical devices to help you... It is just a bow with a string on it. The other bows have all these fancy "precision" sights and stablizers, and all the widgets that allow you to shoot bullseyes all day. (A bullseye is a 3 1/2 inch diameter circle at 20 yards away). The saying went something like....
    A Recurve shooters attitude is "I hope I hit!, and is happy when he does hits" The other shooters attitude is "I hope I don't miss, and is embarrased if he does!" <g>
    Dwayne
    Ability to Fly:
    Feb 2004
    Germany
    @DWAYNE,
    we are running a bit off topic, but here is one more:
    That "blinky light" could be seen as something that...
    works, doesn't work, works, doesn't work. . . .
    and this is certainly something to be investigated in depht.
    @atmoski
    sorry, the last posts mgiht have been of no use on your way to solve the 3-wire LCD problem, but they probably have made you smile.
    Dec 2003
    Wichita KS
    Hello NavMicroSystems,
    NMS >>sorry, the last posts mgiht have been of no use on your way to solve the 3-wire LCD problem, but they probably have made you smile.<<
    Well, in actuallity, I was helping another Gent on the 3 wire system. Unfortunately I have not had the experience with the chips that he wanted to use.
    I have built a 2 wire system to control a LCD, and on the same principal, I built a single pin LCD controller. The baudrate is alarmingly fast, and you do not need any Serin or Serout rountines. That means any pin you want (that is a output) can control the LCD. I mainly did this, so that I could work with a bunch of 12f675's to control some LCD's and display data to it, when it reads the AD off of the 12f675.
    And it gives me a little more knowledge on how the timing is on these little PIC chips. They are a whale of a lot different than the Philips chips! But fun to work with...
    And by the way...Yes, I do enjoy good laughs, smiles, and conversations. Thanks!
    Dwayne
    Ability to Fly:
    atomski's Avatar
    atomski Guest
    Hey guys no prb,
    I enjoy when people around me have a
    positive attitude. I would like to find
    out more about your 1 wire protocol,
    though. Hope you can shine some light
    on this subject for me please. Thanks!
    Sincerest regards,
    I do recall posting this sometime over the last year... it could have been to the email forum... it may be of interest...
    atomski's Avatar
    atomski Guest
    Hey Mel,
    Yes, it looks nice and I'd like to try it out.
    However, as I said I have a whole pile of
    74HC595's and I'd like to use them. BTW
    I found a basicstamp source code for the
    3-wire LCD interface, but the syntax is so
    different I couldn't make it out
    Vlad
    Dec 2003
    Wichita KS
    Hello Folks,
    I will post the receiver and transmitter part of the 1 pin Xcvr.
    The principal lies upon the receivers timing, in connection with the transmitters timing. You only have two critical points to ponder.
    1. The initial Rcvr *must* be slower than the transmitter until it receives the start bit.
    2. The Rcver *must* be faster than the transmitter after receiving the start bit.
    After #2 starts or begins, you control your Baud rate by the transmitter, *NOT* the receiver, or both.
    I wanted the overhead of the transmitter to be almost zero. The receiver was a 16f648A, and its only job was to control the LCD, so instead of using a interupt (which you can), I left the receiver in a loop, waiting for data communication from the 12f675. When a full byte is received, the 648 checks to see if it is a LCD command byte or a LCD data byte. (x254) if it is a command byte, it tells the LCD to accept next byte as a command, and waits for the next byte.
    Dwayne
    It has been 100 percent reliable so far. When I get home, I will post the code.
    Ability to Fly:
    Jun 2006
    Bangalore, India
    Default code?
    Melanie could you please give me the code to interface your circuit?
    May 2007
    Republic Serbia
    Wink hi vlad
    Pa de si bre Vlad puno pozdrava od Tanga.
    Quote Originally Posted by shahidali55 View Post
    That was over 3 years ago...you know that right?
    And there is code around here...just needs a bit of searching...who knows, maybe you could even write code yourself!
    T.Jackson's Avatar
    T.Jackson Guest
    Post
    That's a good idea - using a Hex D Flip-Flop. So basically when Q6 is low the LCD's disabled, (the diode sinks current from the 4k7) then Q6 swings high allowing the data line to re-enable the LCD after clocking in the bits you want.
    Last edited by T.Jackson; - 5th June 2007 at 17:11. Reason: 174 is certainly not a parallel shift register like I initally first thought
    T.Jackson's Avatar
    T.Jackson Guest
    Post
    Give him a break - writing code for this is a lot easier said than done.
    Jun 2006
    Bangalore, India
    Couldn't find anything using search.
    Jun 2006
    Bangalore, India
    I didn't know what PBP was before 3 years.
    I don't think any code in PBP was posted for 3 or 2 wire interface till now.
    I tried to understand the code given on http://www.rentron.com/Myke1.htm.
    But couldn't really understand the command sequence. I didn't really get how the RS and E lines of the LCD are being handled.
  1. More Servo Woes
    By chrisshortys in forum mel PIC BASIC Pro
    Last Post: - 13th May 2009, 09:40
  2. Please help with EDE702 - Serial to LCD interface
    Last Post: - 30th October 2008, 03:48
  3. LCD will not start
  4. having problems with Hantronix 20x4 lcd
    By Rhatidbwoy in forum mel PIC BASIC Pro
    Last Post: - 22nd December 2005, 13:22
  5. Replies: 6
    Last Post: - 10th June 2005, 08:31
