read 1 sensor with 2 PICs?
Results 1 to 10 of 10
    For the supply, if the two PICS have a COMMON GROUND and BOTH a very close to 5 v supply ( do not forget PIC protection diodes on the inputs ...), I don't see any problem ... as your sensor impedance is low enough.
    For common Ground ... keep in mind there should be only 1 common ground connection point to avoid "ground loops" ...
    a scheme of each of your ADCs inputs could help greatly too ...
    PICn_n_grinnin's Avatar
    PICn_n_grinnin Guest
    Alain,
    The two PICs are on seperate circuit boards, each with its own 5V. switching regulator, and there is a common ground between the boards. I'm a little unclear as to what you mean by the protection diodes. What type of diode and where should they be placed?
    Pete
    These are INTERNAL Pic protection diodes ... If supply voltage of the 2 Pics were differents, that could create problems, so we must not forget them in such situations !!!
    One more point, is your sensor connected to ground on one of its sides ???
    Alain,
    OK, my face is sufficiently red! I forgot to take my smart pill this morning. As I mentioned, I will try the single resistor and will let you know the results.
    Pete
  1. How to drive the Vinculum VDIP1 in UART mode
    By BrianT in forum Code Examples
    Last Post: - 23rd May 2013, 12:34
  2. 32 bit square root
    Last Post: - 6th May 2009, 03:37
  3. USB-FTDI[UM232R] with PIC16f877a
    By bjox in forum USB
    Last Post: - 23rd February 2008, 22:40
  4. Displaying messages with only 7 (or 4) LEDs on a stick...
    Last Post: - 20th May 2007, 08:35
  5. 18F452 "Unknown Processor" errors
    By schwinn_rider in forum mel PIC BASIC Pro
    Last Post: - 27th April 2006, 03:56
