serial comm problem
Results 1 to 17 of 17
    no big solution... it's working here using
    Private Sub Form_Load()
        Option1(0).Value = True
        MSComm1.CommPort = 1
        MSComm1.Settings = "2400,n,8,1"
        MSComm1.DTREnable = False
        MSComm1.RThreshold = 1
        MSComm1.InputLen = 1
        MSComm1.PortOpen = True
    End Sub
    Private Sub Command1_Click()
        Dim pinstate As Byte
        If Option1(0).Value = True Then
            pinstate = 1
            Else
                pinstate = 0
            End If
        MSComm1.Output = Chr(255) & Chr(pinstate)
    End Sub
    Private Sub form_unload(Cancel As Integer)
        MSComm1.PortOpen = False
    End Sub
    on the PICSide
    INCLUDE "modedefs.bas"
    Si       VAR PORTA.4
    RELAY    VAR PORTB.2
    pinstate VAR BYTE
        SerIn Si,n2400,[255],pinstate
        IF pinstate=1 Then
            GoSub Relayon
            Else
               GoSub Relayoff
            EndIF
    Relayon:
        High RELAY
    Relayoff:
        Low RELAY
    sorry, try a lower resistor value and be sure you share the same ground, be sure you place 0.1 uF cap close to your PIC and be sure of your crystal speed and capacitor value.
    Schu4647 have also point an interesting fact... be sure it's not the relay who create the bug.
    > I haven't found a relay yet I could directly drive
    There are many 5v Reed Relays, many of which need less current than an LED... and some even have integral back-emf diodes across the coil which dispenses the need for any other external components. Meder Electronic www.meder.com springs to mind, at prices in volume of under $1 a lump, they're not exactly budget breaking either.
    Dec 2005
    Quote Originally Posted by Melanie
    There are many 5v Reed Relays, many of which need less current than an LED... at prices in volume of under $1 a lump, they're not exactly budget breaking either.
    And they tend to be rated for billions of cycles.
    Apr 2006
    Michigan
    Those are girly relays. I use manly relays.
    Dec 2005
    Quote Originally Posted by schu4647
    Manly relays can be turned on by girly relays.
    Haven't girly things always turned-on manly things since time began?
    I'd just want to add (before we digress too far), that as a matter of good practice, I'd never hang any power sucking switching component on the same supply line as that for your PIC (and that goes for your vibrator motor!). That +5v (3.3v) line is sacred. Your PIC and some other logic and that's it. All your Power devices get hung on the raw input supply, not on the nice regulated PIC supply. In following that rule, I've NEVER experienced any problems switching power devices.
    Big Power Relays need a big magnetic field to slam shut their contacts in order to carry Amps and things... and a big magnetic field unfortunately can only be generated by a current which a PIC can't provide. And if you did, then the induced back-emf and spikes means you'll have to significantly filter your PICs supply to stop it tripping out.
    Take my advice... NO power devices on the same supply line as your PIC.
    And if I may add to Melanies post, use if possible optocouplers to drive external power devices. It is the most secure method of isolation.
    I had to go twice on a town up in the mountains 250Km away, for an automation once I made with 16C55 and assembly lanquage, but with no isolation and finally understood that I was too inexperienced that time in industrial automation design (long time ago, I would say...).
  1. Problem using Microloader and Uart Comm at the same time
    By guanerrr in forum mel PIC BASIC Pro
    Last Post: - 3rd August 2007, 10:31
  2. Big characters on HD44780 4x20
    Last Post: - 7th January 2007, 03:21
  3. Serial Communication Problem
    Last Post: - 23rd February 2006, 03:11
  4. Replies: 8
    Last Post: - 11th November 2004, 21:08
  5. 16F877, DS18S20 and Serial Comm Problem
    By YellowTang in forum mel PIC BASIC Pro
    Last Post: - 26th April 2004, 11:36
