Numeric Values
Results 1 to 9 of 9
Thread: Numeric Values
    Feb 2003
    Salt Lake City, Utah USA
    Smile
    Quote Originally Posted by Armando Herjim
    ... What do you mean with a "string string"?? ...
    Poor choice of words on my part – there is no string variable in PBP. i.e., you cannot have RX_Var = “Hi There” in PBP even though it is allowed in most traditional BASIC programs if RX_Var is declared as a string variable (See Visual Basic for example). You can have
    X[0]=”H”
    X[1]=”i”
    X[2]=” “
    etc.
    You have a few choices from what I can see. You can make sure you always send and receive 4 digits of a decimal number and use DEC as Steve suggested. Or you could “roll your own” with your array values: (highly unoptimized but should get the point across)
    NewValue VAR WORD
    RX_Var[0]=51
    RX_Var[1]=52
    RX_Var[2]=53
    RX_Var[3]=54
    IF RX_Var[0] = “ “ THEN GoSomeWhere
    NewValue = RX_Var[0] - “0”
    FOR X = 1 to 3
    IF RX_Var[X] = “ “ THEN GoSomeWhere
    NewValue = (NewValue * 10) + RX_Var[X]-”0”
    NEXT X
    You also can probably do it with all the options of SERIN2 but I have not used them enough to be able to suggest the format. Someone else?
    Good Luck,
    Paul Borgmeier
    USA
    Feb 2003
    Smile
    A quick after thought - why not just send and receive your data a low byte and a high byte of a word sized variable and be done.
    For example
    X var word
    X = 456 ' your "desired" value
    send
    X.lowbyte = 200
    X.highbyte = 1
    then X will be 456 - done.
    Paul
    Smile Good Idea!
    Hey that seems to be an excellent idea. Thank you very much!!!
  1. Formating numeric values to text
    By Andre_Pretorius in forum General
    Last Post: - 1st August 2009, 09:39
  2. WRITECODE stores wrong 14-bit word values in FlashMEM
    By BobPigford in forum mel PIC BASIC Pro
    Last Post: - 26th June 2009, 05:35
  3. Looking at pic basic pro symbol values in mplab 8.15a simulator
    By ukemigrant in forum mel PIC BASIC Pro
    Last Post: - 16th May 2009, 14:18
  4. Funny PULSIN values: what is going on???
    Last Post: - 30th April 2008, 09:02
  5. 16F877A problem: "coupled" digital values
    By Lupo83 in forum General
    Last Post: - 4th December 2007, 13:46
