Numeric Values
Results 1 to 9 of 9
Thread: Numeric Values
    Question Numeric Values
    Hello again, hope everybody´s fine!
    I have some little problem here. I am receiving serial data (numbers) and I need to compare them (is it "compare them" well written?), anyways, I need to do so, but it seems that when I try to compare this data, it is taken as ascii code, so I always get the same result no matter what the data is. Is there a way to make a kind of cast to convert this ascii data into numeric data so I can do my comparison?
    Thank all of you and special thank to Adam who´s I´ve been receiving too much help from.
    Armando.
    look for DEC modifier or #
    Post your code here, it will be easier to answer
    Feb 2003
    Salt Lake City, Utah USA
    Smile
    As Steve said, post your code so we do not have to guess. If your data is in ASCII, then
    Decimal 0 = 48 in ASCII
    Decimal 1 = 49 in ASCII
    Decimal 2 = 40 in ASCII
    etc.
    You can convert your received ASCII numbers to decimal by
    X VAR Byte ' Received value
    X = X – 48 ' convert from ASCII to decimal (or X = X - “0” does the same thing)
    If X < 7 THEN Something ' your compare
    or you could do your compare like this
    If X < “7” THEN Something ' “7” = decimal 55 but is 7 in ASCII
    Again, post your code if you cannot make yours work.
    Paul Borgmeier
    USA
    Talking Here´s my code
    Well, thank you for your answers. The code I am using is something like this:
    hserin [skip 2, str var\4 \32]
    I know that I´m gonna recieve numbers, so I need to do something like this:
    if var == 100 then
    code here...
    if var < 100 then
    code her...
    code here...
    just that var contains ascii data. I had already though about some code to convert that ascii data to numbers but I´d like to know if there is something quicker because I receive data from 1 to 3 digits and I´m trying to write the less lines possible.
    Thanks to all of you again.
    Armando Hdez.
    Feb 2003
    Smile
    Armando,
    I believe “str” it is referring to an array string not a string string. You should have something like this as the variable declare. (Let's change your variable name from VAR to RX_Var since VAR is reserved)
    RX_Var var byte[4]
    Then with your call, if your incoming data looks like this
    49 ' ascii 1
    50 ' ascii 2
    51 ' etc.
    52
    53
    54
    hserin [skip 2, str RX_Var\4 \32 ]
    Your data captured data will look like
    RX_Var[0]=51
    RX_Var[1]=52
    RX_Var[2]=53
    RX_Var[3]=54
    If you need more help or suggestions, let us know ...
    Paul Borgmeier
    USA
    Smile Ohhhh
    Ok thank you! You´re right I have an array but then you are telling me there´s another way to get a string of characters serialy?? What do you mean with a "string string"?? Thank you very much I really appreciate it!
    Armando.
  1. Formating numeric values to text
    By Andre_Pretorius in forum General
    Last Post: - 1st August 2009, 09:39
  2. WRITECODE stores wrong 14-bit word values in FlashMEM
    By BobPigford in forum mel PIC BASIC Pro
    Last Post: - 26th June 2009, 05:35
  3. Looking at pic basic pro symbol values in mplab 8.15a simulator
    By ukemigrant in forum mel PIC BASIC Pro
    Last Post: - 16th May 2009, 14:18
  4. Funny PULSIN values: what is going on???
    Last Post: - 30th April 2008, 09:02
  5. 16F877A problem: "coupled" digital values
    By Lupo83 in forum General
    Last Post: - 4th December 2007, 13:46
