broadband over powerline
Results 1 to 8 of 8
    Default broadband over powerline
    hello
    can any one help me how to make a powerline ethernet adaptor using a PIC microcontroller
    any idea or what i shoud know to do that
    thanks for any help
    by the way are Xin/Xout helps or not
    It's been done... and it's cheap...
    ZyXEL PL100 Powerline Ethernet (about US$60-80)
    * High Speed 85Mbps Powerline Solution
    * Uses existing power cables and plugs
    * Easy to install and manage (Centralised management utility)
    * Up to 300m - 3 times the distance of standard Ethernet over copper wires
    * 56 Bit encryption for added privacy
    * 16 PL-100's per private group
    * 4 Groups per network
    By the time you get a design, and the parts, and make a board, and do the program and factor-in all your time, it'll cost you ten times what walking down to the shops and buying one would cost. Then you can use all that extra time in taking it apart and learning how they did it...
    Default why melani
    hello melani
    i dont't know why melani stop me again and again
    if u know how? share your knowldge
    if not it's not necessary to show us your scales to find the solution
    i really know it's excets around 2000
    but we can't get it here
    so is it Forbidden to ask stubed questions or what
    the question was how to make one
    not is't already done
    u r the administrator and it's not fair to peer me
    or to show u how to deal with the site guests
    No, yours wasn't a stupid question, and that was a sensible answer on my part, so I honestly can't see why you seem to take umbrage with it.
    If you want to make one, go ahead, I'm not stopping you - but like I said, you will spend many times more on your little project than what I pointed out was a readilly available, good, feature rich and very cheap solution to a complex problem. Interfacing Ethernet across power lines is not someting for a novice, if you suddenly stop posting, then we'll know why.
    Oh, and thanks for the info Melanie... You're welcome, next time I won't bother replying on this forum...
    Italy
    An impossible task with a PIC microcontroller.
    (You will need a 32bit MCU).
    To develop from scratch a product like that, a group
    of ten engineers will have to work about two years if
    they use a chipset made for Power Line Communications
    and if they buy the TCP/IP networking software.
    Powerline Communication Chipset:
    http://pdfserv.maxim-ic.com/en/ad/MAX2986-AD.pdf
    Best regards,
    Luciano
    Certainly Luciano for a device of the complexity and sophistication of the ZyXEL product, but for something a lot slower and far more basic (although functionally it'll still do the job of conveying Ethernet over Power Lines), you can do it for around US$250 and about two weeks worth of effort (assuming you know what you're doing!).
    If it's for yourself, it's just not worth doing. Far easier to grab your Credit Card (or if you don't have one borrow a friends) and order one ready made - it doesn't matter where you are in the world - nowadays the world is a small place, you can buy just about anything from anywhere.
    If it's for a commercial project, then asking how to make one on this forum indicates you don't know what you're doing... so either you want the schematics and code handed to you for free, or you're looking at closer to two years rather than two weeks...
    Either way, enjoy the experience...
    I wasn't aware I'd ever stopped you doing anything. Please explain yourself...
