Music Input
Results 1 to 22 of 22
Thread: Music Input
    [QUOTE=malc-c]Ok I've looked at the PDF (http://www.ee.washington.edu/stores/...ear/mc3340.pdf) for that device, but how does an electronic volume control fit in with my bass extraction / filter thingy ???
    I just thought you had understood the presence of D1,D2,Q1,Q2 ... around U1A ...
    as for good films : do not make presume the end too early ...
    PS: You buy your PICS from Radiospares ??? ... Who said Cr ...??? Ohhhhh.
    RePS: Elektor is the same price ...
    Apr 2006
    New Hampshire USA
    Lightbulb Try Color Organ
    Hi Malcolm,
    A pre-disco name for "disco light" could be "color organ".
    I made a color organ in the early 1970's of the last century.
    It was great before the word kewl, or way cool, or even cool was used to describe "neat" things.
    There seems to be a lot of information on line about color organs. A search may turn up a lot of circuit ideas and schematics.
    For instance:
    http://www.tinaja.com/glib/muse108.pdf
    Describes a color organ as;
    Your speaker level input
    audio is somehow safety isolated and
    then lowpass, bandpass, or highpass
    filtered into (usually) three or more
    channels. Each channel’s output is
    then converted into some dc control
    voltage. That dc control voltage then
    modulates a "power amplifier" of
    some sort. Which in turn relates the
    amount of audio energy in the band
    to the brightness of one or more
    colored lights. For instance, the lows
    might be red, the mids green, and the
    highs blue. Or whatever"
    Now you may be interested, in a single channel "Bass" (lowpass), but the principle should be the same.
    PicBASIC should truly turn the simplistic color organ into a true disco light. But be careful to isolate your circuit from the power lines (mains). It is also good practice to isolate the circuit from the input device as well.
    This is a fun project and we hope you post where your journey takes you so we can all learn with you.
    -Adam-
    Talking one more piece to the puzzle ...
    May I point out this little circuit from the far east...
    http://www.selectronic.fr/includes_s...ek/HT2040A.pdf
    ... really ... cool !!!
    malc-c's Avatar
    malc-c Guest
    Quote Originally Posted by Acetronics
    Thats wicked ! .... nice find
    Apr 2006
    New Hampshire USA
    Smile zimmerframe
    Quote Originally Posted by Malcolm
    God you make me feel old, I think the last century bit made me reach for my zimmerframe and I'm only mid 40's
    Ha, I had to Google "zimmerframe", we have them in this country, just different names... Made me smile...
    http://www.thefreedictionary.com/Zimmer+frame
    What a great find. The HT2040A IS a disco light. (they might think it is for Christmas lights, but we know better.) All in one part.
    Side Notes:
    One of the interesting things, about the artistic mode of visual music, is sloppier is better!
    Normally, the goal is to sharpen filters. Make the "cut-off", at band edges, as sharp as possible, without causing "ringing" or other ill effects. However, with "music changed into light", it is better to have overlapping filters, to cause a blending of the lights. Much more interesting patterns, come about, when the band edges overlap.
    Very simple L-C or even R-C passive filters are not only adequate, but even desirable
    "A Project Too Far."
    What might be interesting:
    Have mirrors mounted on some type of PIC controllable devices. This could be stepper motors, syncros, voice coils, linear motors etc..
    The front panel could be some type of translucent, diffusing rear projection screen. Maybe, something as simple as a "suspended ceiling" florescent light diffusion lens.
    The light would be modulated as in a standard colour (color) organ.
    But, the mechanical device would move the modulated colours around by volume (loudness). Who knows, maybe higher on the panel could represent louder musical notes.
    It seems like this might add a third dimension to the mix. ?
    -Adam-
    Wink The last ... but not least
    Hi,Malc
    I've another lightshow including a Basic stamp interpreter chip ( In easy words : PicBasic compatible ... but some timings, may be, are to be corrected )
    From Electronique Pratique june 2000 issue ... Here, all is done by soft ( no "miracle" filter to cut and paste ... )
    malc-c's Avatar
    malc-c Guest
    I do get the feeling that I'm re-inventing the wheel... but then again, its all good learning experience
    malc-c's Avatar
    malc-c Guest
    Quote Originally Posted by Pic_User
    Thanks for the lead, I'll google colour (or color) organ and see what I get.
    No worries on the mains isolation. I use solid state relays that have built in opto isolation. Its a lot safer and easier than messing about with triacs and thryistors like the good old days... I built my first sound to light in '77 consisting of a three way passive crossover, three mains to 6v ac transformers (using the secondry as the primary on the audio) and three 206 thyristors... never really thought about the amp become live at mains potential !!!!
    I'll keep you guys posted of any development I get, and hopefully Melanie may let me post the final project and schematic in the respective forums when its completed.
  1. Sony LanC Program
    By l_gaminde in forum Code Examples
    Last Post: - 25th September 2009, 19:51
  2. floating A/D input
    By muddy0409 in forum mel PIC BASIC Pro
    Last Post: - 28th April 2009, 14:21
  3. LED "capacitance" won't get lower
    Last Post: - 3rd May 2007, 21:31
  4. Timing input pulses and re-outputting them
    Last Post: - 28th February 2007, 02:50
  5. Using LEDs as light sensors
    Last Post: - 30th December 2006, 23:19
