Music Input
Results 1 to 22 of 22
Thread: Music Input
    malc-c's Avatar
    malc-c Guest
    Sorry I dow to your superior knowledge.. so what's an analogue comparator input then.. will it not do the same thing... ??
    Cool Already cooked example
    Hi, Malc
    Some years ago, Elektor committed such a project with a 16F84 ... you could have a look to their input stage ...
    16F628 is a "bigger" '84 ...no ???
    PS : Project 000107 ... note everything Downloadable ...
    malc-c's Avatar
    malc-c Guest
    Thanks for that, but me been a tight ass brit object to having to pay a quid to obtain access to the article... especially when the HEX and ASM are free !!
    I did come accross this project, which appears to use the filtered bass to trigger an NE555 to provide the logic pulse to trigger another NE555 which can run as an astable free runner or mono-stable triggered by the music.
    The actual chase generator is a 4017 decade counter. ( full project details http://sound.westhost.com/project62b.htm )
    I might just try this, however it seems a but of an overkill to use all those op-amps and an NE555 to provide the input into a PIC.... I'll keep googling and yahooing and see what turns up
    An Analogue Comparator allows you to trip your input pin at different voltage levels determined by an internal or external reference. So, if you set your Reference voltage at say 500mV, you can trip the Comparators Output on or off at 500mV rather than the usual trip level for a Digital I/O pin.
    By sweeping the Comparators Reference Voltage, you can then use its input as a cheapo ADC. However, the internal Reference in the 16F628 only has two scales of 16 steps, and allowing for a settling time would not be very good for Audio input sampling.
    So, in reply to your query, an Analogue COMPARATOR does what it says... it COMPARES your input against a Reference. Whilst an Analogue to Digital CONVERTOR (ADC) will give you a snap-shot of your current Analogue input in Digital form. The two are NOT the same.
    The 16F628 has TWO COMPARATORS on-board and NO ADC's. ADCIN only functions with ADC's which is why it's named ADCIN (that what I love about microprocessors, they name everything so obviously!).
    Quote Originally Posted by malc-c
    Let's see how much you hope to save ( let's do the whole count for the project ) ... makes me laugh !!!
    mmmh, by the way ... have a look to Freescale MC 3340 P datasheet. An old Elektor ( once more, ... !!! ) summer issue show a really nice application
    You'll be more than happy : datasheet is free ...
    you fast draw, mmmmh ???
    PS : 5or 8 £ for a pre-programmed basic PIC ( 675,628,84 ...) ... you're joking, I hope !!!
    malc-c's Avatar
    malc-c Guest
    Melanie,
    Thanks for the explanation. I understand where my confusion came from now !
    malc-c's Avatar
    malc-c Guest
    Ok I've looked at the PDF (http://www.ee.washington.edu/stores/...ear/mc3340.pdf) for that device, but how does an electronic volume control fit in with my bass extraction / filter thingy ???
    Quote Originally Posted by Acetronics
    Whoops - thanks for pointing out the typo... should be £5 like the rest.. now corrected.
    And before you ask, that just covers the cost of the PIC and postage to me, then the cost of the post, packing and paypal charges when sending it out again !
    [QUOTE=malc-c]Ok I've looked at the PDF (http://www.ee.washington.edu/stores/...ear/mc3340.pdf) for that device, but how does an electronic volume control fit in with my bass extraction / filter thingy ???
    I just thought you had understood the presence of D1,D2,Q1,Q2 ... around U1A ...
    as for good films : do not make presume the end too early ...
    PS: You buy your PICS from Radiospares ??? ... Who said Cr ...??? Ohhhhh.
    RePS: Elektor is the same price ...
    Apr 2006
    New Hampshire USA
    Lightbulb Try Color Organ
    Hi Malcolm,
    A pre-disco name for "disco light" could be "color organ".
    I made a color organ in the early 1970's of the last century.
    It was great before the word kewl, or way cool, or even cool was used to describe "neat" things.
    There seems to be a lot of information on line about color organs. A search may turn up a lot of circuit ideas and schematics.
    For instance:
    http://www.tinaja.com/glib/muse108.pdf
    Describes a color organ as;
    Your speaker level input
    audio is somehow safety isolated and
    then lowpass, bandpass, or highpass
    filtered into (usually) three or more
    channels. Each channel’s output is
    then converted into some dc control
    voltage. That dc control voltage then
    modulates a "power amplifier" of
    some sort. Which in turn relates the
    amount of audio energy in the band
    to the brightness of one or more
    colored lights. For instance, the lows
    might be red, the mids green, and the
    highs blue. Or whatever"
    Now you may be interested, in a single channel "Bass" (lowpass), but the principle should be the same.
    PicBASIC should truly turn the simplistic color organ into a true disco light. But be careful to isolate your circuit from the power lines (mains). It is also good practice to isolate the circuit from the input device as well.
    This is a fun project and we hope you post where your journey takes you so we can all learn with you.
    -Adam-
  1. Sony LanC Program
    By l_gaminde in forum Code Examples
    Last Post: - 25th September 2009, 19:51
  2. floating A/D input
    By muddy0409 in forum mel PIC BASIC Pro
    Last Post: - 28th April 2009, 14:21
  3. LED "capacitance" won't get lower
    Last Post: - 3rd May 2007, 21:31
  4. Timing input pulses and re-outputting them
    Last Post: - 28th February 2007, 02:50
  5. Using LEDs as light sensors
    Last Post: - 30th December 2006, 23:19
