Music Input
Results 1 to 22 of 22
Thread: Music Input
    Hi Malcolm. I did something similar a while back with a 12F675 and a portable radio. This program flashes several LED's with the beat of the music. Audio was taken from the audio feed to the volume control. The use of the ADC command automatically converts the port to analog.
    ANSEL = 0 'all inputs digital
    CMCON = 7 'comparators off
    DEFINE OSCCAL_1K 1 ' Set OSCCAL for 1K device to accurize osc
    @ DEVICE MCLR_OFF, INTRC_OSC, WDT_ON, BOD_ON, PWRT_ON, PROTECT_ON
    TRISIO = %11111111 ' all inputs for now
    'high & low commands convert to outputs
    X VAR BYTE 'adc variable
    START:
    ADCIN 0, X
    IF X > 2 Then High GPIO.2 'TURN ON LED'S ON GPIO.2
    IF X <=2 Then Low GPIO.2 'OFF LED'S
    GOTO START
    malc-c's Avatar
    malc-c Guest
    Thanks for the reply,
    Sounds good (sorry no pun intended), I'll have a play and see what I can do.
    Cheers
    If and when you get ADCIN to work with a 16F628A, come back and tell us how you did it. That PIC hasn't got any ADC's...
    malc-c's Avatar
    malc-c Guest
    Sorry I dow to your superior knowledge.. so what's an analogue comparator input then.. will it not do the same thing... ??
    Cool Already cooked example
    Hi, Malc
    Some years ago, Elektor committed such a project with a 16F84 ... you could have a look to their input stage ...
    16F628 is a "bigger" '84 ...no ???
    PS : Project 000107 ... note everything Downloadable ...
    malc-c's Avatar
    malc-c Guest
    Thanks for that, but me been a tight ass brit object to having to pay a quid to obtain access to the article... especially when the HEX and ASM are free !!
    I did come accross this project, which appears to use the filtered bass to trigger an NE555 to provide the logic pulse to trigger another NE555 which can run as an astable free runner or mono-stable triggered by the music.
    The actual chase generator is a 4017 decade counter. ( full project details http://sound.westhost.com/project62b.htm )
    I might just try this, however it seems a but of an overkill to use all those op-amps and an NE555 to provide the input into a PIC.... I'll keep googling and yahooing and see what turns up
    An Analogue Comparator allows you to trip your input pin at different voltage levels determined by an internal or external reference. So, if you set your Reference voltage at say 500mV, you can trip the Comparators Output on or off at 500mV rather than the usual trip level for a Digital I/O pin.
    By sweeping the Comparators Reference Voltage, you can then use its input as a cheapo ADC. However, the internal Reference in the 16F628 only has two scales of 16 steps, and allowing for a settling time would not be very good for Audio input sampling.
    So, in reply to your query, an Analogue COMPARATOR does what it says... it COMPARES your input against a Reference. Whilst an Analogue to Digital CONVERTOR (ADC) will give you a snap-shot of your current Analogue input in Digital form. The two are NOT the same.
    The 16F628 has TWO COMPARATORS on-board and NO ADC's. ADCIN only functions with ADC's which is why it's named ADCIN (that what I love about microprocessors, they name everything so obviously!).
    Quote Originally Posted by malc-c
    Let's see how much you hope to save ( let's do the whole count for the project ) ... makes me laugh !!!
    mmmh, by the way ... have a look to Freescale MC 3340 P datasheet. An old Elektor ( once more, ... !!! ) summer issue show a really nice application
    You'll be more than happy : datasheet is free ...
    you fast draw, mmmmh ???
    PS : 5or 8 £ for a pre-programmed basic PIC ( 675,628,84 ...) ... you're joking, I hope !!!
  1. Sony LanC Program
    By l_gaminde in forum Code Examples
    Last Post: - 25th September 2009, 18:51
  2. floating A/D input
    By muddy0409 in forum mel PIC BASIC Pro
    Last Post: - 28th April 2009, 13:21
  3. LED "capacitance" won't get lower
    Last Post: - 3rd May 2007, 20:31
  4. Timing input pulses and re-outputting them
    Last Post: - 28th February 2007, 01:50
  5. Using LEDs as light sensors
    Last Post: - 30th December 2006, 22:19
