read 1 sensor with 2 PICs?
Results 1 to 10 of 10
    PICn_n_grinnin's Avatar
    PICn_n_grinnin Guest
    Default read 1 sensor with 2 PICs?
    Hello All,
    I am trying to read a resistive type sensor connected to two PICs, a 16F88 and a 16F685. When either PIC is connected to the sensor by itself, it works fine. But when both are connected, neither one reads correctly. The sensor has a range of 0 to 90 Ohms, and I'm using a 100 Ohm resistor between the input pin and Vcc on each PIC.
    I'm sure you're asking yourselves why I don't just have one PIC perform both functions... well it's a long, ugly story. Let's just say I'm stuck with this setup and I have to make it work (or not). I'm using the default settings for ADCIN.
    Any tips, hints, enlightened insights would be much appreciated. I really need to put this project (and myself) to bed.
    Thanks in advance,
    Pete K.
    P.S. I have a hunch that the problem lies more in the circuit than in the software. Then again, the last time I had a hunch I lost a hundred bucks at the Blackjack table in Vegas!
    Oct 2003
    holland
    Can you bring this part to an opamp, wired as a buffer, and the output of the buffer to the inputs of your pic's.
    Aug 2005
    An A/D chip with serial output could also be an option.Feed the serial output to both Pic's.
    Mat and Arnie - thanks for your replies. I should have mentioned that the circuits in question have already been built, and any changes other than adding a resistor here, a diode there, would mean a re-design and I'm afraid that at this point, that's not an option.
    Perhaps I should rephrase my original question to read: Should the setup I'm currently using work, or am I just wasting my time trying to get it to? I just realized that what I'm doing, in effect, is connecting the A/D input pins of the two PICs together with the output from the sensor, and having the two inputs tied to each other might be confusing the A/D converters in both PICs. Am I thinking along the right lines here? If so, would there be a fairly simple work-around, or should I just scrap the whole idea and go with one of your suggestions?
    Thanks again, guys. My butt's in a sling here, and I really appreciate your input.
    I just had another though as I was keying this in - how about (if I'm forced to redo this mess) using a third PIC that has an A/D converter and two hardware PWM channels on it, with the A/D connected to the sensor and each of the HPWM outputs going to one of the two existing PICs?
    Hi, Picn' ...
    QUOTE [ and I'm using a 100 Ohm resistor between the input pin and Vcc on each PIC. ]
    Wonder if there is really ONE resistor for EACH Pic ...
    Logically, there must be only ONE resistor in series with your probe ... so, the second PIC input must NOT have a 100 Ohms resistor from +5v ...
    I'm not sure ... but that can be a very good reason for misrunning ...
    Hello Alain,
    Thanks for your reply. I think we tried the setup with only one resistor, but now I can't remember for sure... I'll be going to the lab later today and will try that. Do you think there should not be a problem with having the two PIC's A/D pins tied together?
  1. How to drive the Vinculum VDIP1 in UART mode
    By BrianT in forum Code Examples
    Last Post: - 23rd May 2013, 13:34
  2. 32 bit square root
    Last Post: - 6th May 2009, 04:37
  3. USB-FTDI[UM232R] with PIC16f877a
    By bjox in forum USB
    Last Post: - 23rd February 2008, 23:40
  4. Displaying messages with only 7 (or 4) LEDs on a stick...
    Last Post: - 20th May 2007, 09:35
  5. 18F452 "Unknown Processor" errors
    By schwinn_rider in forum mel PIC BASIC Pro
    Last Post: - 27th April 2006, 04:56
