Using WDT as a Temp Sensor?
Results 1 to 14 of 14
    Apr 2005
    Default Using WDT as a Temp Sensor?
    Has anyone used the watchdog timer as a temp sensor per AN720?
    http://ww1.microchip.com/downloads/e...tes/00720c.pdf
    Just curious on the results and if this has been done using PBP. In the mean time I will start trying to write the code myself.
    Thanks in advance,
    New England
    Looks like an interesting project. The PBP code should not be difficult to write - remember to disable PBP's automatic watchdog timer clearing function (and then to clear the WDT as needed elsewhere in your code).
    Calibrating the setup without a controlled temperature environment seems like it will be rough.
    Some of the charts in the app note show a pretty bad deviation at around +30°C, not a good sign as far as reliability goes.
    Also - Microchip says:
    The linearity of the WDT is not guaranteed, but has been observed.
    Not very encouraging. How about the TCxx series of temp sensors from Microchip instead?
    Arch
    "Data sheets? I ain't got no data sheets. I don't need no data sheets. I don't have to read any stinking data sheets!"
    not worse than a using a NTC !!!
    New England
    Was just thinking about this idea some more - couldn't this be used to calibrate PBP's 'SLEEP' and 'NAP' commands?
    Arch
    Apr 2005
    How do I disable PBP autoclear of the WDT?
    Apr 2005
    Looks like DEFINE NO_CLRWDT is the command
    Feb 2003
    Salt Lake City, Utah USA
    Smile
    Also see Melanie's post on getting the WDT to timeout even without the Define set.
    @ goto $
    http://www.picbasic.co.uk/forum/show...ight=no_clrwdt
    I have not read the AN (yet) and am therfore not sure if this is helpful. It sounds like you could do some stuff in your program and then sit in a tight loop and count time outs ...
    Paul Borgmeier
    Salt Lake City, Utah.
    USA
  1. Need a cheap touch sensor idea.. here it is
    By mister_e in forum Code Examples
    Last Post: - 16th April 2016, 22:42
  2. Graphic LCD with PICbasic pro
    By amindzo in forum mel PIC BASIC Pro
    Last Post: - 25th November 2012, 11:45
  3. RH/Temp Sensor Example Code
    Last Post: - 15th June 2006, 15:55
  4. Temp sensor problem
    Last Post: - 14th June 2006, 14:49
  5. 1 wire Temp sensor
    By PortlandJohn in forum General
    Last Post: - 25th November 2005, 16:21
