control servo motor by using pic16F84A
Results 1 to 11 of 11
    waterlee2000's Avatar
    waterlee2000 Guest
    Default control
    Include "modedefs.bas"
    si var PORTA.0
    pos var byte
    servo var byte
    cont var byte
    trisb = 0
    start:
    serin si,N2400,servo,pos
    for cont = 0 to 50
    pulsout servo,pos
    pause 15
    next cont
    goto start
    this program just can clockwise only.... then how to write the anti anti clockwise program???
    what the different between trisb=0 and trisb=%00000000 ???
    what the above mean serin si,N2400 ,servo,pos?? can you explain
    See the lower section of this project page for info on how pulsout works to
    control hobby servos http://www.rentron.com/Micro-Bot/IR_Nav.htm
    -Bruce
    tech at rentron.com
    waterlee2000 Guest
    Default control servo motor
    that is used by IRLED... my circuit and program as below... please help me check it and correct it... if can, explain to me... thanks... urgency
    waterlee2000 Guest
    Default hello
    Quote Originally Posted by waterlee2000
    Look at the bottom of the page. It explains how to drive a servo with pulsout.
    The example in your attachment should also work assuming you are sending a
    servo # followed by a position from 100 to 200 as explained on the page
    above when using a 4MHz osc.
    -Bruce
    tech at rentron.com
    waterlee2000 Guest
    Default discussion
    then... my lecture said that if you use this circuit, you better choice B because no need any declaration but make sure you program is in true language!!! can you help me check??? or what are you suggestion for this circuit?? A or B??
    is it A using C language and B is using basic language??? i cannot understand C and basic, i thought both is C language!!! what the difference???
    thanks...
    Both examples are in BASIC language (though each is slightly different), but unless you have the manual dexterity to accurately toggle S1 at 2400 baud, then example A will not apply.
  1. More Servo Woes
    By chrisshortys in forum mel PIC BASIC Pro
    Last Post: - 13th May 2009, 08:40
  2. Replies: 10
    Last Post: - 26th May 2008, 07:00
  3. Help with Servo Control Please!
    By wireman22 in forum mel PIC BASIC Pro
    Last Post: - 7th June 2007, 18:15
  4. Control RC servo via Parallax Servo Control
    Last Post: - 17th September 2005, 08:18
  5. Servo control with 12F629
    By achilles03 in forum mel PIC BASIC Pro
    Last Post: - 23rd June 2005, 23:34
