gps programming
Results 1 to 3 of 3
Thread: gps programming
    Jun 2006
    Default gps programming
    i am new to programming & i need help on a gps module.the only info i want from the module is speed in mph & kph.i want to read this on 3 seven segment leds.i was thinking of using the 16f877 pic.if there is something better i would like to know. if someone has a program or could help me with programming,i would appreciate it.thanks chuck
    Jun 2005
    Wisconsin
    You may want to post in the GPS section of this forum, or take a look at a few of those posts.
    Default Format
    If you look at the NMEA format, I believe that those figures are in there. Serial in the data into an array. Then just send those parts of the array to the lcd screen, or led segments.
  1. GPS $GPRMC to PIC16F684. Need help with SERIN2
    Last Post: - 27th November 2009, 09:47
  2. Data Programming Error at 0000
    By cpatnoi in forum mel PIC BASIC Pro
    Last Post: - 22nd May 2009, 03:37
  3. GPS clock timing !
    By bethr in forum mel PIC BASIC Pro
    Last Post: - 3rd July 2008, 20:11
  4. Replies: 2
    Last Post: - 28th April 2006, 12:10
  5. GPS Receiver
    By lester in forum Adverts
    Last Post: - 22nd February 2006, 12:47
