Wire worked by not wireless
Results 1 to 17 of 17
    mankan's Avatar
    mankan Guest
    Default Wire worked by not wireless
    Dear Gurus,
    Below is the code I am using to build a wireless data transfer, I started by building a wired connection and it worked very fine but once I go wireless nothing works.
    Any idea, hint, help is greatly appreciated.
    Mankan
    '* Name : Receiver.BAS *
    '* Notice : Copyright (c) 2006 [select VIEW...EDITOR OPTIONS] *
    '* : All Rights Reserved *
    '* Date : 5/10/2006 *
    '* Version : 1.0 *
    '* Notes : *
    INCLUDE "modedefs.bas"
    '@DEVICE PIC16F628, WDT_ON
    '@DEVICE PIC16F628, BOD_ON
    '@DEVICE PIC16F628, PROTECT_OFF
    '@DEVICE PIC16F628, MCLR_ON
    DEFINE NO_CLRWDT
    '* Variable declarations
    Header var BYTE
    Counter VAR BYTE
    Packet VAR BYTE
    End_Of_Data VAR BYTE
    counterA VAR BYTE
    ErrorFlag var bit
    MyData var byte
    ManchesterWord Var WORD
    Temp_Byte var byte[5]
    Temp_Word var WORD[5]
    x VAR BYTE
    send_word VAR WORD
    SYNCH VAR byte
    SYNCH=$C6
    CMCON = 7
    VRCON = 0
    TRISB.1 = 1
    INPUT PORTB.1
    PORTB.1 = 1
    pause 10
    Loop:
    Header = 0
    HIGH PORTB.6
    'SERIN PORTB.1,N300,[SYNCH],Header,Counter,Packet,End_Of_Data
    'SERIN PORTB.1,N300,[SYNCH],ManchesterWord.lowbyte,ManchesterWord.highbyte
    SERIN PORTB.1,N300,[SYNCH],send_word.lowbyte,send_word.highbyte
    Temp_Word[0] = send_word
    For x=1 to 4
    SERIN PORTB.1,N300,300,Loop,send_word.lowbyte,send_word. highbyte
    Temp_Word[x] = send_word
    next x
    for x=0 to 4
    ManchesterWord = Temp_Word[x]
    GOSUB DecodeManchester
    Temp_Byte[x] = MyData
    next x
    Low PORTB.6
    Header = Temp_Byte[0]
    PAUSE 100
    if Header = 96 THEN
    gosub GLOW_PIN7
    if Counter = 2 Then
    gosub glow_pass
    goto loop
    TimeOut:
    call GLOW_TIMEOUT
    goto loop
    GLOW_PASS:
    HIGH PORTB.5
    PAUSE 50
    LOW PORTB.5
    PAUSE 50
    GLOW_PIN7:
    HIGH PORTB.7
    PAUSE 50
    LOW PORTB.7
    PAUSE 50
    GLOW_TIMEOUT:
    HIGH PORTB.6
    PAUSE 500
    LOW PORTB.6
    PAUSE 500
    DecodeManchester:
    ErrorFlag=0
    For counterA=0 to 7
    if ManchesterWord.1=0 then
    MyData.7=0
    If ManchesterWord.0=0 then ErrorFlag=1
    MyData.7=1
    If ManchesterWord.0=1 then ErrorFlag=1
    ManchesterWord=ManchesterWord>>2
    if counterA<7 then MyData=MyData>>1
    next counterA
    /**********END OF Receiver*********************/
    /**********Start of Transmitter*********************/
    '* Name : Transmitter.BAS *
    '* Date : 5/2/2006 *
    '* Version : 1.0 *
    '* Notes : *
    DEFINE NO_CLRWDT
    CMCON = 7
    VRCON = 0
    TRISB.2 = 0
    Header VAR BYTE
    End_Of_Data con 24
    SYNCH VAR byte
    SYNCH=$C6
    Counter VAR BYTE
    Packet VAR BYTE
    counterA VAR BYTE
    MyData var byte
    x VAR BYTE
    send_word VAR WORD
    Header = 96
    pause 10
    OUTPUT PORTB.2
    PORTB.2 = 0
    OUTPUT PORTB.4
    PORTB.4 = 0
    OUTPUT PORTB.5
    PORTB.5 = 0
    Counter = 2
    Packet = 78
    Temp_Byte[0] = 96
    Temp_Byte[1] = 16
    Temp_Byte[2] = 26
    Temp_Byte[3] = 36
    Temp_Byte[4] = 46
    start:
    MyData = Header
    for x=0 to 4
    MyData = Temp_Byte[x]
    gosub EncodeManchester
    Temp_Word[x] = ManchesterWord
    nEXT X
    'SEROUT PORTB.2,N300,[126, SYNCH,Header, Counter, Packet, End_Of_Data]
    'SEROUT PORTB.2,N300,[126, SYNCH,ManchesterWord.lowbyte, ManchesterWord.highbyte]
    SEROUT PORTB.2,N300,[1263, SYNCH]
    for x=0 to 4
    send_word = Temp_Word[x]
    PAUSE 1
    SEROUT PORTB.2,N300,[send_word.lowbyte, send_word.highbyte]
    next x
    CALL GLOW_LED
    goto Start
    GLOW_LED:
    HIGH PORTB.5
    PAUSE 50
    LOW PORTB.5
    PAUSE 50
    EncodeManchester:
    ManchesterWord = 0
    for counterA=0 to 7
    if MyData.0 = 0 then
    ManchesterWord.14=1
    ManchesterWord.15=1
    if CounterA<7 then ManchesterWord = ManchesterWord>>2
    MyData=MyData>>1
    Next CounterA
    /************END OF TX****************/
    New Jersey
    Default Probably not software related
    I'm not one of the most experienced people on this forum but I have made successful links with PIC's without wires. Can you tell us what you are using in the way of hardware? If your code works with wires, your code should work without wires. Have you ever done a wireless link with PIC's before?
    Chris
    New Jersey
    I forgot to mention, it is possible that your software may have an issue with timing. When I use a wireless link, I typically give a little more time for the transmit and receive signals....maybe an extra 10 to 20ms.
    mankan's Avatar
    mankan Guest
    Default Hello Chris,
    Chris,
    Thank you very much for the reply. This is my first project with the PIC. Is there any other issue apart from time-to-transmit?
    Do you see anything wrong with my code? It worked fine with the wires.I have even grounded the Rx DataIn pin to overcome the noise.
    I am using laipac 434 series of Tx/Rx.
    Mankan
    New Jersey
    I have never used those but I have used Linx Technologies LR series modules. I found that without a 10K pullup resistor (to +5V) on the RX side, they would not work at all. The TX side did not need anything. Are you making only a transmitter and receiver or are you making two transceivers. Don't forget that you cannot have to transmitters transmitting at the same time. With the Linx modules, if you don't pull down the PDN line, the transmit port will always be open making it impossible to send data. Of course, if only using one TX and one RX, this is not a problem. The other thing you may look at is interference in the surrounding area. Let me know if you still have problems.
    Dec 2005
    The Laipac modules (also widely available under other names) use ASK and the suprerregenerative receiver has AGC/ATC so the output line will have continuous noise in the absence of a signal. I would not try to use serial in and out but would use some type of preamble that will serve to tell the receiver that a message is coming and also allow it to set its AGC/ATC. I use the NEC IR protocol and have never had much of a problem sending/receiving. However, it may or may not be the best choice depending on the type of data you need to transmit. The length of messages casn be a determining factor.
    I don't recall what Bruce Reynolds uses in his examples but he does have some examples using these modules on his web site.
  1. Need Single wire serial LCD converter example
    By polymer52 in forum mel PIC BASIC Pro
    Last Post: - 16th December 2009, 03:30
  2. Wireless Tachometer - Design Help
    By DanPBP in forum Off Topic
    Last Post: - 3rd May 2009, 10:06
  3. RS485 Vs Wireless (TWS-434A)
    By koossa in forum Off Topic
    Last Post: - 11th April 2009, 13:40
  4. Wireless communication gear.
    By toalan in forum Off Topic
    Last Post: - 17th March 2005, 17:33
  5. RPM with wire and PIC
    By Dwayne in forum mel PIC BASIC Pro
    Last Post: - 14th December 2004, 21:42
