Proton net
Results 1 to 2 of 2
Thread: Proton net
    CBUK's Avatar
    CBUK Guest
    Unhappy Proton net
    hi, can anybody help with the evaluation board proton net? i brought it a while back and have only just got around to having a play with it..... the demo thats included with the PIC that shows the webpage and analoge voltages works fine, however when i compile the pb_udp.bas under proton + v2.1.3 the datagram software doesnt work, nor does the board ping and all the serial comms replies back with is Tx ARP request, or NIC frame error. now i know a little bit about networks and tried to ping the iosoft web demo and that ping'd fine so it seems to be pointing towards the pb_udp code ? or compiling as i see an update made to the software was made for the proton+ v2.0
    many thanks for any help
    Chris
    Chris, methinks you're on the wrong forum for Proton playthings... try...
    http://www.picbasic.org/
    and select forum...
    They're so similarly named it's easy to fall into the wrong one... I go by colour schemes... this one is a Blue Curacao and the other one is a Pizza with extra Cheese...
  1. Microcode Plus vs Proton Suite
    By rdxbam in forum mel PIC BASIC Pro
    Last Post: - 24th October 2009, 03:41
  2. Problem using Else
    By tazntex in forum mel PIC BASIC Pro
    Last Post: - 14th August 2008, 23:48
  3. Proton PICBASIC vs MeLabs PICBASIC
    By Fredrick in forum General
    Last Post: - 11th January 2008, 22:51
  4. PICBasic Pro vs. Proton Dev System
    By hjsong in forum mel PIC BASIC Pro
    Last Post: - 6th February 2007, 05:17
  5. Proton Commands & statements
    By Lotondo in forum mel PIC BASIC Pro
    Last Post: - 7th November 2006, 00:37
