Using WDT as a Temp Sensor?
Results 1 to 14 of 14
    Apr 2005
    Default Using WDT as a Temp Sensor?
    Has anyone used the watchdog timer as a temp sensor per AN720?
    http://ww1.microchip.com/downloads/e...tes/00720c.pdf
    Just curious on the results and if this has been done using PBP. In the mean time I will start trying to write the code myself.
    Thanks in advance,
    New England
    Looks like an interesting project. The PBP code should not be difficult to write - remember to disable PBP's automatic watchdog timer clearing function (and then to clear the WDT as needed elsewhere in your code).
    Calibrating the setup without a controlled temperature environment seems like it will be rough.
    Some of the charts in the app note show a pretty bad deviation at around +30°C, not a good sign as far as reliability goes.
    Also - Microchip says:
    The linearity of the WDT is not guaranteed, but has been observed.
    Not very encouraging. How about the TCxx series of temp sensors from Microchip instead?
    Arch
    "Data sheets? I ain't got no data sheets. I don't need no data sheets. I don't have to read any stinking data sheets!"
    not worse than a using a NTC !!!
    New England
    Was just thinking about this idea some more - couldn't this be used to calibrate PBP's 'SLEEP' and 'NAP' commands?
    Arch
    Apr 2005
    How do I disable PBP autoclear of the WDT?
    Apr 2005
    Looks like DEFINE NO_CLRWDT is the command
    Feb 2003
    Salt Lake City, Utah USA
    Smile
    Also see Melanie's post on getting the WDT to timeout even without the Define set.
    @ goto $
    http://www.picbasic.co.uk/forum/show...ight=no_clrwdt
    I have not read the AN (yet) and am therfore not sure if this is helpful. It sounds like you could do some stuff in your program and then sit in a tight loop and count time outs ...
    Paul Borgmeier
    Salt Lake City, Utah.
    USA
    Apr 2005
    I'm still trying to figure out how to get this to work. I think undersand the concept of the Microchip AN, but I am having a little difficulty implementing it.
    This is my understanding, basically you have two timers WDT and TMR0. TMR is based on a temperature compensated crystal (in my case a temperature compensated INTOSC) and WDT is based on a non temperature compensated RC.
    A prescaler in the code is setup so that timer TMR0 rolls over multiple times before the WDT rolls over. By counting the number of times TMR0 rolls over in a WDT period an inference on the temperature can be made.
    The confusion I am having is how to setup the WDT correctly. How do I setup the WDT up so that it rolls over without reseting the pic, and how do I tell that the WDT rollover has occured. Since it may matter I am using a 12F675 for this project. I assume I set the pic fuse to not use the WDT to reset the pic, but I am not sure how to use it in my code.
    I think I am missing one minor piece and I will be able to get this to work.
    Thanks for any help
    New England
    Quote Originally Posted by modifyit
    Thanks for any help
    I'm not experienced in assembly, but it looks like the idea in the app note is that you WANT the WDT to cause a PIC reset. Once the PIC is reset by a WDT timeout, you then check to see if the WDT timeout caused the PIC to reset, or if some other condition caused a reset. There are several flags that will tell you whether a PIC has just powered up, or has reset due to various other conditions - one of them being a WDT timeout. See "STATUS" and "PCON" registers in the device data sheet.
    You'll need to set the WDT ON in the config fuse.
    Arch
    Apr 2005
    If I am counting the number of times the TMR0 rolls over before a WDT reset, wouldn't I have to use eeprom to save this count variable? It does not seem that this is the intent of the AN to me, so I wonder if there is a way to watch when the WDT rolls over without having it reset the pic.
    New England
    Hi modifyit,
    If you check the app note section:
    "FIGURE 1: FIRMWARE FLOW DIAGRAM"
    there is a flowchart describing how the code works... RESET > TestWDT > Etc
    This is from the 12F675 data sheet about resets, and what registers are changed on various resets:
    Some registers are not affected in any RESET
    condition; their status is unknown on POR and
    unchanged in any other RESET. Most other registers
    are reset to a RESET state on:
    Power-on Reset
    MCLR Reset
    WDT Reset
    WDT Reset during SLEEP
    Brown-out Detect (BOD) Reset
    They are not affected by a WDT wake-up, since this is
    viewed as the resumption of normal operation. TO and
    PD bits are set or cleared differently in different RESET
    situations as indicated in Table 9-4. These bits are
    used in software to determine the nature of the RESET.
    See Table 9-7 for a full description of RESET states of
    all registers.
    A simplified block diagram of the On-Chip Reset Circuit
    is shown in Figure 9-4.
    The MCLR Reset path has a noise filter to detect and
    ignore small pulses. See Table 12-4 in Electrical
    Specifications Section for pulse width specification.
    Arch
    Apr 2005
    maybe this is what I am missing: Does the WDT reseting of the PIC clear existing variables? For example will a variable "count" be zeroed out on this reset or will it maintain its value prior to the reset?
    Apr 2005
    Here is what I've got so far on a 12F675
    'defines
    DEFINE OSCCAL_1K 1
    define OSC 4
    DEFINE NO_CLRWDT
    'end defines
    'includes
    'Include "Elapsed.bas"
    'end includes
    ' Config Fuses
    @ __config _INTRC_OSC_NOCLKOUT & _CPD_OFF & _CP_OFF & _BODEN_ON & _MCLRE_ON & _PWRTE_ON & _WDT_ON
    ' Variable Definitions
    LED VAR GPIO.1
    TEMPERATURE_CNT VAR WORD
    TEMPERATURE VAR WORD
    'End Variable Defs
    ' Initialize
    INTCON=%10100000
    CMCON=7
    TRISIO=%11111101 ' Input 0,2,3,4,5 Output 1
    ANSEL=0
    'End Initialize
    ON INTERRUPT GOTO TMR:
    OPTION_REG.3=1 ; set WDT prescaler to 1:8
    OPTION_REG.2=0
    OPTION_REG.1=1
    OPTION_REG.0=1
    startup:
    LED=0
    IF STATUS.4=0 THEN  ;CHECKS TO SEE IF WDT TIMEOUT OCCURED
        TEMPERATURE = TEMPERATURE_CNT ;TEMPERATURE EQUALS COUNT VARIABLE
        TEMPERATURE_CNT=0  ;CLEARS COUNT VARIABLE
    @CLRWDT            ;CLEARS STATUS.4 REG BACK TO 1
    IF TEMPERATURE>300 THEN
        LED=1 ;IF TEMPERATURE IS ABOVE A DETERMINED COUNT VARIABLE TURN ON LED
        LED=0
    GOTO MAIN
    DISABLE INTERRUPT
    TMR: ;INTERUPT OCCURS WHEN TMR0 ROLLS OVER
        TEMPERATURE_CNT=TEMPERATURE_CNT+1 ;INCREMENT COUNT VARIABLE
        INTCON=%10100000                  ;CLEAR TMR0 INTERRUPT
    resume
    ENABLE INTERRUPT
    Apr 2005
    At this point I can't seem to get the TMR0 timer to work with the code above.
  1. Need a cheap touch sensor idea.. here it is
    By mister_e in forum Code Examples
    Last Post: - 16th April 2016, 23:42
  2. Graphic LCD with PICbasic pro
    By amindzo in forum mel PIC BASIC Pro
    Last Post: - 25th November 2012, 12:45
  3. RH/Temp Sensor Example Code
    Last Post: - 15th June 2006, 16:55
  4. Temp sensor problem
    Last Post: - 14th June 2006, 15:49
  5. 1 wire Temp sensor
    By PortlandJohn in forum General
    Last Post: - 25th November 2005, 17:21
