chronometer
Results 1 to 11 of 11
Thread: chronometer
    Mentor, Ohio
    Smile
    Hi nicolasronan,
    Just for starters, perhaps what may work from a simplistic mode would be to take Darrel Taylor's ELAPSED TIMER program and merge it with a Real Time Clock chip. Since I have been working with RTC's latley that's the first thing that comes to my mind. Perhaps over the next few days some of this forum's gurus might come up with a different solution. But I think this might be an easy way to get started. You could use the SQW ouput of the RTC to increment a counter on the PIC then say every 60 "ticks" (60 Seconds) read the RTC and display the time while continuing with the elapsed timer program. The elapsed timer program is interrupt based so you have to be careful of how much time you spend servicing the RTC read and display portions of the program. Also look at Paul Borgmeire's EASY CLOCK programs. They are very easy to follow and maybe the answer to what you are looking for.
    I suggest you search this forum under the CODE EXAMPLES section for further information. Believe me, there's a wealth of information on this site!!!
    BobK
    Feb 2003
    Salt Lake City, Utah USA
    Smile
    As Bob mentioned, I posted some short code examples that automatically keeps time - the first of the two updates an lcd display. It works best for long term accuracy. If you do not need more that long term second to second accuracy, they might just work. The first program given keeps time in hh:MM format. The second in HH:MM:SS format. You could easily add the :SS to the first program and add your stopwatch timer function in the section marked “Do something here.”
    These program are here http://www.picbasic.co.uk/forum/forumdisplay.php?f=11
    Take a look. Also worth mentioning is Melanie's “Olympic Timer,” which is in the example code section of this forum as well.
    Good Luck,
    Paul Borgmeier
    USA
    May 2006
    Default chronometer
    thanks for your help
    i have test this code of melanie for a clock and it s ok
    and i test too olypic timer it s ok too.
    thanks melanie
    now i do a mixt this two file.
    May 2006
    Default stopwatch + clock
    hello
    i 've work the code and it s ok on my easypic3 (board test).
    but the real time is bad. when i use the stopwath, the clock stop a small time.
    i use a pic 16F877A at 8Mhz.
    can you help me?
    too i don't know how take some partial time on (for) the stopwatch;
    an idea?
    thanks
    May 2006
    up
    help please and sorry for my english
    Feb 2003
    Smile
    What kind of time tracking and accuracy are you after? (e.g., 10ths of Seconds, Seconds, Minutes, Hours, etc.)
    Paul Borgmeier
    USA
    May 2006
    for 15min realtime, clock it s 13 min
    The original Olympic Timer has a Calibration Value that you could adjust.
    The Clock code I posted primarily as an example of One Button usage did not, though there was provision for it.
    Add in a Calibration value and you are in business.
