How to configure the clock??!!
Results 1 to 4 of 4
    sergio.elias's Avatar
    sergio.elias Guest
    Default More info
    Hi Bruce... I´m not using the USB module. I want to run the CPU core at 40 MHz..... my crystal is a 40 MHz parallel cut (it requires capacitors).... and doesn´t work on HS mode... I dont know what to do... I´ve tried so many different configurations...
    Hi Sergio,
    Above 25MHz, you'll need a TTL type clock oscillator. HS and HSPLL support
    up to 25MHz primary osc.
    Make sure you have the latest verion of the 4550 data sheet rev DS39632C
    and look in the electrical characteristics section at table 28-8, parameter 1A.
    With a 40MHz TTL type clock oscillator, and EC or ECIO oscillator modes, it
    should work fine.
    With this config you should still have full-speed USB, 40MHz CPU clock, and
    have port function on RA6.
    CONFIG PLLDIV=10,CPUDIV=OSC1_PLL2,USBDIV=2,FOSC=ECIO_EC
    -Bruce
    tech at rentron.com
    http://www.rentron.com
  1. Single digit 7 Seg LED clock - PIC16F88
    By thirsty in forum Code Examples
    Last Post: - 17th July 2009, 08:42
  2. EM4095 Chip, get Clock and Data signals?
    By mindthomas in forum mel PIC BASIC Pro
    Last Post: - 19th August 2008, 06:27
  3. Shiftout/in
    By BobEdge in forum mel PIC BASIC Pro
    Last Post: - 23rd August 2007, 11:48
  4. Help with sound command in 2 programs
    Last Post: - 5th July 2007, 20:36
  5. How to configure SPI in PICBASIC PRO?
    Last Post: - 15th April 2007, 18:31
