PID controller in 16F737
Results 1 to 9 of 9
    Sep 2003
    Vermont
    Quote Originally Posted by joeri
    I knows this document and will have a look at it.
    My intention was to have a PID which I can use afterwards for any process I want.
    The NTC is no problem. It comes with the original oven, and I measured the curves to translate the R-value towards °C.
    What are the resistance values over the range desired? Will you use it for non lead solder, and will it (oven) be quick enough to heat up so as not to over stress the components?
    I use a Cuisinart digital convection oven, and it is a little on the slow side to hit 225c. No problems though, other than pizza tasting a little metallic.
    Ron
    at 100°C I have 11 kOhm; at 150°C I have 3 kOhm; at 260°C I have 500Ohm. I use a current source which drives a small current through the NTC, then I amplify the voltage over the NTC with a opamp and bring it into the analog pic input. So far, so good.
    The oven is a samsung with 1500W. I added two heat resistors from a waffle machine (another 1000W), so total of 2,5KW.
    This boosts quite fast. Also, I have a fan to equalize the temp inside the oven. The complete oven is packed in rockwool.
    But my problem is the PID. Any experience on how to work with negative errors (overshoot)?
    The calculate PID values are:
    gain= 10
    I= 0,04
    D = 100
    So it seems I have a PD controller. Due to the slow process, that might be ok. Or not?
    Sep 2003
    Vermont
    gain= 10
    I= 0,04
    D = 100
    It sounds like the rock wool is overkill, plus you want to cool things down pretty quickly once soldered. I crack the door of the toaster oven slightly for my high tech solution.
    I really think the PID may be overkill. If it were me, I would take the current value at a given time and compare it to a desired constant value with ...
    heat_loop:
    for time = 1 to 10
    If curr_temp_val < set_temp_val then
    relay = 0; A lower number means the temp is too high.
    else relay = 1 ; temp too low
    next time
    goto get_next_heat_increment ; Put next temp constant into set_temp_val and start again.
    Otherwise, the relay pulls in to increase temperature.You can check/regulate the temp this way until the next time increment is reached. At this point, update set_temp_val and compare. You can make the time increments every 10 seconds, or every second for that matter. A heavily insulated unit will require you to cut off power to the elements early, or you will have substantial overshoot. I'd say to use the rockwool for the hydroponic "tomatoes", and use less insulation or an automatic vent to the outside.
    I will keep it in mind for the 'tomatoes'.
    I have a fan in the oven that can cool things down quickly.
    Also, I made a LCD-screen in the oven to read out the temp.
    Thanks for the help, but I want to implement the PID in order to have the controller ready when I want to use it for more sophisticated processes..
  1. LM628 - Precision Motion controller - PID
    By infinitrix in forum mel PIC BASIC Pro
    Last Post: - 1st July 2009, 06:51
  2. PID controller with PIC
    By poyet16 in forum Forum Requests
    Last Post: - 16th November 2006, 05:21
  3. PID CONTROLLER help..
    By tkly36 in forum mel PIC BASIC Pro
    Last Post: - 12th April 2006, 08:19
  4. PID controller and serin/serin2...help
    Last Post: - 8th April 2006, 11:19
  5. PID controller
    By toalan in forum Off Topic
    Last Post: - 18th February 2005, 16:05
