HPWM frequency range
Results 1 to 7 of 7
    Aug 2004
    Santa Clara Calif. USA Silicon Valley
    Talking Hpwm Max Frequency
    Hi Folks
    I looked at the 2.45 pbp manual and it says the max HPWM freq using any crystal is 32.767KHZ. Am I misreading the post or has this changed with the newer version? I would love to get HPWM working at 40KHZ for IR remote control apps.
    Sep 2005
    Campbell, CA
    The solution is to not use the PBP HWPWM command at all. Simply write to the registers directly. For example:
    PR2 = $1F ' PWM register, 158 Khz@20Mhz, 7 bits
    T2CON = %00000100 ' Prescale 1 - Needed for PWM
    CCPR1L = PWMVal >>2 ' Divide Value by 4
    CCP1CON.5=PWMVal.1
    CCP1CON.4=PWMVal.0
    Charles Linquist
    Feb 2003
    Salt Lake City, Utah USA
    Smile
    I too, must admit I never use the HPWM command. I write to the registers directly just as Charles suggested. Most (if not all) of the PICs that have hardware PWM have an easy to follow 4 step procedure for setting the registers correctly. (e.g., for the 16F628A, see section 9.3.3). In addition to Charles' example check out MElabs example here
    http://www.melabs.com/resources/samples/pbp/hardpwm.bas
    (Yes, the calcs are a tad confusing at first, but once you get it you will never go back.)
    Paul Borgmeier
    USA
    Dec 2005
    Quote Originally Posted by paul borgmeier
    I find the formulas obfuscate things. Using the MElabs example, with OSC=4MHz each instruction cycle takes 1µS. The period for 1kHz is 1/1000=.001=1000µS=1000 instruction cycles. With the prescaler set to 4, 1000 becomes 250 and since it's Base0 it becomes 249. The duty cycle is the number of instruction cycles that the output is high. 20% of 1000 = 200 and 80% of 1000 = 800. All you are doing is defining the period and duty cycle in numbers of instruction cycles. Once you grasp what's involved you can do the calculations in your head.
    jcsquire's Avatar
    jcsquire Guest
    Default Thanks a LOT!
    Paul, Charles, dHouston: Thanks so much for not just answering my question but guiding me back to the literature so that I can figure out future questions for myself. I (and I'm sure Blind Al too) consider myself very lucky to have such expertise available.
    - Jim
  1. HPWM command and oscillator frequency
    By RussMartin in forum mel PIC BASIC Pro
    Last Post: - 8th March 2009, 23:41
  2. HPWM of the port of two HPWM
    By ja2rqk in forum mel PIC BASIC Pro
    Last Post: - 25th April 2007, 16:05
  3. inaccurate frequency using TMR1 PI18F452
    By nkarpovich in forum mel PIC BASIC Pro
    Last Post: - 14th October 2006, 17:22
  4. sound command & music
    By trying in forum mel PIC BASIC Pro
    Last Post: - 26th May 2006, 15:14
  5. 3 HPWM channels
    Last Post: - 4th April 2006, 03:43
