Russ,
I am not sure what you are trying to do. Without an OScope, you probably cannot see what your program is doing because it is doing it so fast.
PAUSE 1 ' WHY DO I NEED THIS PAUSE STATEMENT? WITHOUT IT,
'PORTB.6 NEVER GOES LOW. WITH IT, PORTB.6 IS
'LOW ONLY 1 mS
It will and does go low with or without your Pause statement. Without the Pause, RB6 is low only for a few uS, which is hard to detect. Your program is humming along at 1,000,000 instructions per second. You make RB6 low with line 5 and then immediately make it high again with line 1) with only a few instruction in between. With the pause of 1 (= 1000uS) inlcuded on line 7, you basically get a 1mS off time before you turn it back on with line 1. Clear as mud?
For reference
LOOP:
1) HIGH PORTB.6
2) PAUSE 1000
3) HIGH PORTB.7
4) PAUSE 100
5) LOW PORTB.6 'DOES NOT GO LOW!
6) LOW PORTB.7
7) PAUSE 1 ' WHY DO I NEED THIS PAUSE STATEMENT? WITHOUT IT,
'LOW ONLY 1 mS.
8) LOW PORTB.6 'DOES NOT STAY LOW
9) GOTO LOOP
Paul Borgmeier
Salt Lake City, Utah
USA
