Custom array of ports using array?
Results 1 to 23 of 23
    Excellent!
    <table><tr><td valign=top></td><td>Thanks Steve. That's a bug. Thanks for finding it. The Vaddr allows it to work with WORD variables for the 16-bit ports. Then, these lines...
              if (PortAction == 0)                   ; read
                  MOVE?TT  P, Pbit, PortVar, VarBit
                  if (PortAction == 1)               ; write
                      MOVE?TT  PortVar, VarBit, P, Pbit
    Should have used Vaddr instead of PortVar. I got the VarBit, but missed the Vaddr.
    I will make the changes. &nbsp;http://www.pbpgroup.com/Vport/VirtualPort.bas.txt
    Yeah, that new chair idea is sounding pretty good
    and, yup spruced up the avatar a bit. Hopefully it's not too annoying.
    Read the part about HighJack again.</td></tr></table>
    Thanks again,
    &nbsp; &nbsp; DT
    May 2006
    Del Rio, TX, USA
    Question
    Alright. I've gotten though the code but still have one question. Why use seperate delay code? It's commented as "Similar to PAUSEUS, but ASM interrupt compatible".
    Yet I'm missing something here. Why is this more compatible with ASM interrupts then the PBP PAUSEUS routine? I've been using the PAUSEUS in my current project, with both high and low priority ASM interrupts (18F4620), without any problems. The delays are slightly longer than requested, due to the interrupt occuring in the delay loop (trival for most apps), but no other ill effects I've noticed. This 'error' in delay time would occur with any delay based on code exectuing timing and a loop, unless interrupts were disabled prior to entering the loop. So this can't be the reason.
    Also, I think the PBP routine could be easily called by inserting the following where the delay is required ("_us" is a predefined word variable/literal containing the delay in us):
            movlw   (_us) >> 8
            movwf   R0 + 1
            movlw   low (_us)
            call    PAUSEUSL        ; Delay for us
    PAUSEUS_USED = 1
    One thought that just occured to me. Becuase you use a macro, your not pushing anything onto the stack. So you are avoiding any possible overflow due to interrupts occuring during the delay. Is this it?
    It's not that it's OK to "Be interrupted", but it's OK to be in the routine that does the interrupting.
    PAUSEUS has a couple shortcomings. One, is that it uses PBP's system variables (R0-R8). So it corrupts PBP's flow if it's used in an ASM interrupt without "Instant Interrupts".
    The second is that PAUSEUS has a minimum delay of around 24us @ 4mhz since it figures out the delay Count at run time.
    The DelayUS macro can pause for a little as 1us by calculating the delay at Compile Time, and adding a single NOP if that's all that's needed. Or a 3cycle loop and 2 NOP's if running at 20mhz. And it doesn't use any PBP system vars.
    It can be useful in other programs as well, so I'll show it here again for those that aren't as diligent as you Steve.
    VP_DelayCount  VAR WORD BANK0  ; Used for DelayUS only
    ;----[Similar to PAUSEUS, but ASM interrupt compatible]---(accurate to 1uS)--
    DelayUS  macro T
      local InstCount, LoopCount, DelayLoop, LoopsDone, LeftOver, Offset
    ; -- Calculate number of 3 cycle loops plus leftover nop's to execute --
    InstCount = ((OSC*10/4)*T+5)/10 ; Inst cycles required for delay (Rounded UP)
    LoopCount = InstCount / 3
        if (LoopCount > 255)
    Offset = (LoopCount >> 8) * 7 + 4
    Offset = 0
    ; -- Adjust for HighByte --
    InstCount = InstCount - Offset
        if (Offset > (LoopCount & 0FFh))
    InstCount = InstCount - 4
    Offset = 0
    LeftOver  = InstCount % 3
        if (LoopCount > 0)
            MOVE?CW  LoopCount, _VP_DelayCount
    DelayLoop
            decfsz   _VP_DelayCount, F               ;  1
            goto     DelayLoop                       ;  2   3 per loop, under 256
                movf     _VP_DelayCount + 1, W       ;  1
                btfsc    STATUS, Z                   ;  1
                goto     LoopsDone                   ;  2   4 on last loop
                decf     _VP_DelayCount + 1, F       ;  1
                goto     DelayLoop                   ;  2   7 per highbyte count
    LoopsDone
        if (LeftOver > 0)
            nop
        if (LeftOver > 1)
            nop
    May 2006
    Del Rio, TX, USA
    Exclamation
    Ok,
    Quote Originally Posted by Darrel Taylor
    This makes much more sense than what I was thinking.
    On thing that should be mentioned. It is generally best to keep interrupt service routines (ISR) as short as possible, so that additional interrupts are not "missed" while handling the current interrupt. So putting a pause into an ISR must be used with caution, and with a good understanding of how it will effect other timing related items. One exception to this would be the 16-bit PICs with High and Low priority interrupts (which are supported by PBP), where a pause in a low prority interrupt would not prevent a high priority interrupt from executing. So all the time critical inturrupts could be High Priority.
    Last Post: - 14th June 2016, 07:55
  2. Simple Array Demo
    By Archangel in forum Code Examples
    Last Post: - 15th February 2010, 04:46
  3. Custom array of pins
    By bmagistro in forum mel PIC BASIC Pro
    Last Post: - 28th March 2009, 23:15
  4. Crystalfontz LCD
    By jman12 in forum mel PIC BASIC Pro
    Last Post: - 9th February 2007, 15:04
  5. Making Array of two ports
    By John7 in forum General
    Last Post: - 5th March 2005, 02:20
