Custom array of ports using array?
Results 1 to 23 of 23
    Nice job Paul & Ingvar..;o}
    Yet another version.
    '   BASIC/ASM version = 172 words
        x   var word
        i   var byte
        RelayNum var PORTA
    '    High byte = FSR / Low byte = port pin (or multiple pins)
        RLY1 CON %0000010100000001 ' PORTA|Bit0
        RLY2 CON %0000011001000000 ' PORTB|Bit6
        RLY3 CON %0000011100010000 ' PORTC|Bit4
        RLY4 CON %0000100000000100 ' PORTD|Bit2
        ADCON1 = 7
        PORTA = 0 : PORTB = 0 : PORTC = 0 : PORTD = 0
        TRISA = 0 : TRISB = 0 : TRISC = 0 : TRISD = 0
    RelayOn macro
        movf  _x+1,w ; high byte = pointer to port file reg
        movwf FSR    ; load FSR
        movf  _x,w   ; low byte = port bit to change
        xorwf INDF,f ; toggle port pin
    RelayOff macro
        movf  _x,w   ; reload port pin to toggle
        xorwf INDF,f ; do it
        for i = 0 to 3
            LOOKUP2 i, [RLY1,RLY2,RLY3,RLY4], x ' lookup file reg & XOR pattern
            @ RelayOn
            PAUSE 500
            @ RelayOff
            PAUSE 500
        next i
    -Bruce
    tech at rentron.com
    http://www.rentron.com
    I agree, good stuff!
    Here's another one.
    INCLUDE "VirtualPort.bas"
    Relays  VAR BYTE : Relays = 0
    RelayPort  macro
        Vpin  0, PORTB, 6  ; RELAY1
        Vpin  1, PORTC, 4  ; RELAY2
        Vpin  2, PORTD, 2  ; RELAY3
      OutputPort  RelayPort    ; Set Port to OUTPUT
    Then, here's a test loop to cycle thru the relays...
    i  VAR BYTE
        for i = 0 to 2
            Relays = DCD i
            @  WritePort _Relays, RelayPort
            PAUSE 500
        next i
    Goto Main
    Code size = 104 words, 65 without the PAUSE.
    or you can just...
    Relays = %010
    to turn on RELAY2 by itself.
    Code size = 21 words.
    http://www.pbpgroup.com/Vport/VirtualPort.bas.txt
    HTH,
    Feb 2003
    Salt Lake City, Utah USA
    Smile Amazing yet again ...
    Bruce, Darrel,
    You guys are amazing yet again! I continue to learn and what good fun.
    Paul
    Edit - I am an ASL student (Assembly Second Language) student and removed some code from this post that was not correct.-pb
    Just keeps getting better & better ehh...;o}
    Nice work Darrel.
    -Bruce
    tech at rentron.com
    May 2006
    Del Rio, TX, USA
    Talking Bruce and Darrel Cheated!!!
    Bruce and Darrel,
    You guys cheated(lol). Paul and Ingvar got the job done tidely with PBP. You had to resort to Assembly.
    This is what I love about this forum. Bright, capable folks working together to make a good product (PBP) work even better! I knew in my initial post that there just had to be a way to do this, it just was not documented and was beyond my basic skills. Great learning oppurtunity. I think this is worth putting in the FAQ (in some form) for others to reference later.
    Even though it wasn't my post originally, thanks guys for the great lessons.
    Cheers,
    Thanks Bruce, Paul and Steve,
    And yes I did cheat, by using a module that I had already written.
    I started writing VirtualPort in response to this post from Osiris
    http://www.picbasic.co.uk/forum/showthread.php?t=3554
    He was looking for a way to have a 16-bit port that was scattered across random pins. By the time I got it working, Melanie had already given him what he needed, so I didn't bother posting it.
    But, I soon realized that it was going to be more usefull than originally intended so continued to add more macro's and features, and have managed to do some pretty cool stuff with it.
    Here's how the 16-bit port for Osiris looked...
    MyPort   VAR Word  SYSTEM
    MyPortPins  macro        ; these define which bits go with which pins
        Vpin   0, PORTB,0
        Vpin   1, PORTC,4
        Vpin   2, PORTA,0
        Vpin   3, PORTC,1
        Vpin   4, PORTC,3
        Vpin   5, PORTC,0
        Vpin   6, PORTA,1
        Vpin   7, PORTC,5
        Vpin   8, PORTB,2
        Vpin   9, PORTB,3
        Vpin  10, PORTC,2
        Vpin  11, PORTC,0
        Vpin  12, PORTB,4
        Vpin  13, PORTB,6
        Vpin  14, PORTB,5
        Vpin  15, PORTC,7
    @  OutputPort  MyPortPins
    @  WritePort   MyPort, MyPortPins
    @  InputPort   MyPortPins
    @  ReadPort    MyPort, MyPortPins
    This creates a full 16-bit bi-directional port that can be placed on ANY pins in ANY order.<HR>
    Additional macros can also allow control of Direction, Enable, Latch pulses etc. in the same structure. Here's an 8-bit port with flow control
    Direction  VAR PORTB.5
    Enable     VAR PORTB.1
    Port8_Read  macro
        PinLow _Direction   ; Set direction pin for Read
        Vpin   0, PORTB,0
        Vpin   1, PORTC,4
        Vpin   2, PORTA,0
        Vpin   3, PORTC,1
        Vpin   4, PORTC,3
        Vpin   5, PORTC,0
        Vpin   6, PORTA,1
        Vpin   7, PORTC,5
        PulseLow  Enable, 2 ; Low pulse for 2uS
    Port8_Write  macro
        PinHigh _Direction   ; Set direction pin for Write
        Vpin   0, PORTB,0
        Vpin   1, PORTC,4
        Vpin   2, PORTA,0
        Vpin   3, PORTC,1
        Vpin   4, PORTC,3
        Vpin   5, PORTC,0
        Vpin   6, PORTA,1
        Vpin   7, PORTC,5
    @  OutputPort  Port8_Write
    @  WritePort   MyPort, Port8_Write
    @  InputPort   Port8_Read
    @  ReadPort    MyPort, Port8_Read
    Or that can be simplified like this...
    Port8_Pins  macro
        Vpin   0, PORTB,0
        Vpin   1, PORTC,4
        Vpin   2, PORTA,0
        Vpin   3, PORTC,1
        Vpin   4, PORTC,3
        Vpin   5, PORTC,0
        Vpin   6, PORTA,1
        Vpin   7, PORTC,5
    Port8_Read  macro
        Port8_Pins
    Port8_Write  macro
        Port8_Pins
    <hr>
    Another similar question that keeps popping up every now and then, is how to use an LCD that's not connected to a contiguous nibble of a port.
    This program allows you to do that, and also ties it in with LCDOUT for a "transparent" interface.
    INCLUDE "HighJack.bas"
    @  HighJack  LCDOUT,  _LCDsend
    Clear
    ;----[ Change these to match your LCD ]---------------------------------------
    LCD_DB4   VAR PORTB.0
    LCD_DB5   VAR PORTB.4
    LCD_DB6   VAR PORTC.6
    LCD_DB7   VAR PORTC.3
    LCD_RS    VAR PORTD.1
    LCD_E     VAR PORTD.0
    LCD_Lines     CON 2    ' # of Lines on LCD,  1 or 2+
    LCD_DATAUS    CON 50   ' Data delay time in us
    LCD_COMMANDUS CON 2000 ' Command delay time in us
    ;----[Virtual LCD Port --- 4bit mode]----------------(Don't Change)-----------
    LCD_Port_HNIB  macro           ; Port definition for LCD High Nibble
        Vbit   LCDCDFLAG, _LCD_RS  ; Select Command/Data register
        Vpin   4, _LCD_DB4         ; Put the High Nibble on the bus
        Vpin   5, _LCD_DB5
        Vpin   6, _LCD_DB6
        Vpin   7, _LCD_DB7
        PulseLow  _LCD_E, 2        ; pulse the Enable Pin for 2 us
    LCD_Port_LNIB  macro           ; Port definition for LCD Low Nibble
        Vpin   0, _LCD_DB4         ; Put the Low Nibble on the bus
        Vpin   1, _LCD_DB5
        Vpin   2, _LCD_DB6
        Vpin   3, _LCD_DB7
      OutputPort  LCD_Port_HNIB    ; Set LCD bus to OUTPUT
    ;----[Main program starts here]-----------------------------------------------
    LoopCount  VAR WORD
      lcdout $FE,$80, dec LoopCount
      LoopCount = LoopCount + 1
    goto Main
    ;----[Send a byte to the Virtual LCD PORT]--------called by LCDOUT------------
    TempChar        var  byte
    Char            VAR  Byte
    LCD_Initialized VAR  FLAGS.1
    RSS             VAR  FLAGS.0                ; LCD RS State
    LCDsend:
          @  MOVE?AB  _TempChar                 ; Get char sent by LCDOUT, in WREG
          if !LCD_Initialized then LCD_Init     ; Make sure LCD was Initialized
      LCDAfterInit:
          if TempChar = $FE then RSS=0 : goto LCDsendDone ; next char is Command
          Char = TempChar
      LCDsendCOM:
          @  WritePort   _Char, LCD_Port_HNIB   ; send the High Nibble
      LCDsendShortCOM:
          @  WritePort   _Char, LCD_Port_LNIB   ; send the Low Nibble
          if LCD_RS OR (Char > 2) then
              PAUSEUS LCD_DATAUS                ; Data delay time in us
              PAUSEUS LCD_COMMANDUS             ; Command delay
          if LCD_Initialized then RSS = 1       ; Set RS to Data next time
      LCDsendDone:
    ;----[Initialize the LCD]-----------------------------------------------------
    LCD_Init:
        LOW LCD_RS : HIGH LCD_E   ; Start with RS LOW and Enable High
        Char = 3   : gosub  LCDsendShortCOM : pause 6
                     gosub  LCDsendShortCOM : PAUSE 1
        Char = 2   : gosub  LCDsendShortCOM : PAUSE 1  ; Start 4-bit mode
        Char = $28 : gosub  LCDsendCOM  ; Function Set, 4-bit, 2-line, 5x7
        Char = $0C : gosub  LCDsendCOM  ; Display ON
        Char = $01 : gosub  LCDsendCOM  ; Clear Screen
        Char = $06 : gosub  LCDsendCOM  ; Entry Mode
        LCD_Initialized = 1             ; LCD has been Initialized
    goto LCDAfterInit
    Of course this relies on another program I wrote, "HighJack", to actually link in to LCDOUT. But nobody bothered to respond to this thread
    http://www.picbasic.co.uk/forum/showthread.php?t=3290
    so I never bothered posting it.
    May 2006
    Del Rio, TX, USA
    Darrel,
    I am slowly worming my way through your code and I noticed in VituralPort the local variable "Vaddr" in the the Vpin macro. What's it for? I did a search for it and I only see it being assigned a value (in two places), but otherwise never used.
    Also, you mentioned "HighJack", but did not post it.
    BTW, I have been following your "Wish List" thread. Congrats. Get a good chair! And did you set a new avatar?
    Wish you all success,
    Last Post: - 14th June 2016, 07:55
  2. Simple Array Demo
    By Archangel in forum Code Examples
    Last Post: - 15th February 2010, 04:46
  3. Custom array of pins
    By bmagistro in forum mel PIC BASIC Pro
    Last Post: - 28th March 2009, 23:15
  4. Crystalfontz LCD
    By jman12 in forum mel PIC BASIC Pro
    Last Post: - 9th February 2007, 15:04
  5. Making Array of two ports
    By John7 in forum General
    Last Post: - 5th March 2005, 02:20
