Custom array of ports using array?
Results 1 to 23 of 23
    blainecf's Avatar
    blainecf Guest
    Default Makes a case for functions with pass-by-reference
    Bummer,
    It's these little things that make programming clean and respectable.
    Still, it seems a shame that I can create an aliassed variable that is equivilent to a pin, but not an array element. Seems like the same type of technology.
    So close, yet so far.
    Thanks so much for your input, everyone.
    May 2006
    Del Rio, TX, USA
    Paul:
    Thanks for "chiming in" with a solution. I just want to make sure I understand what your code is trying to do so I can learn from it. I suspected there was a way to shoehorn this idea into PBP.
    Relay[1] = 14  'RB6  is 14 bits offset from RA0
    Relay[2] = 20  'RC4  is 20 bits offset from RA0
    Relay[3] = 26  'RD2  is 26 bits offset from RA0
    This array is establishing an offset from bit.0 on PORTA. I assume that most pics have PORTA-PORTX at consecutive regiester addresses (I only have a couple of datasheets to reference, but that's what I see)
    for i = 1 to 3
         x = relay[i]
         porta.0[x]=1
         PAUSE 1000
         porta.0[x]=0
         PAUSE 300
    next i
    With the Relay[] array containing the correct offets, one can now use that with porta.0[x] to select the desire bit. Since porta.0 points to a bit, the offset [x] is in bits as well.
    Did miss this "feature" in the PBP manual? Can I extend this idea further in that the inclusion of [X] to any reference that points to a register will actually cause an offset reference in accordance to the base reference. ( ie, if it was a word variable that [x] was added to, [x] would actually reference a register x*2 bytes offset?).
    Feb 2003
    Salt Lake City, Utah USA
    Smile Neat Trick
    Steve,
    Yes, you are 100% correct in the logic - that is exactly how it works. This “trick” is not in the manual but first appeared on the PicBasic List in 2002 (http://list.picbasic.com/forum/messages/4011/4739.html? ).
    I remember being excited when this particular email came because it solved a problem I was having at the time. The links posted in my reply #6 above by Bruce and Melanie also clearly demonstrate this trick's use.
    As I understand it, it works for all SF/GP Register locations, not just PORT bits, hence the indexed locations must be sequential like you mentioned. I always check the datasheet if I am going to use it on sequential Ports to make sure they are indeed sequential (and they always have been for the PICs I have used).
    Paul
    Post
    Since portpins rarely move(constants) you could use the LOOKUP statement to get the offset values. Should free up some RAM. The LOOKUP could ofcourse be placed in a subroutine if you need to access it from many different locations in your program. That way saving ROM.
    x      var byte
    i       var byte
    for i = 0 to 3
    '               a  b  c  d
    '               0  6  4  2
         LOOKUP i, [0,14,20,26], x
         porta.0[x]=1
         PAUSE 1000
         porta.0[x]=0
         PAUSE 300
    next i
    /Ingvar
    Feb 2003
    Smile Sweet
    Nice improvement! - The code for what blaine originally wanted to do is getting pretty clean considering it is an undocumented feature.
    Best,
    Paul
    Nice job Paul & Ingvar..;o}
    Yet another version.
    '   BASIC/ASM version = 172 words
        x   var word
        i   var byte
        RelayNum var PORTA
    '    High byte = FSR / Low byte = port pin (or multiple pins)
        RLY1 CON %0000010100000001 ' PORTA|Bit0
        RLY2 CON %0000011001000000 ' PORTB|Bit6
        RLY3 CON %0000011100010000 ' PORTC|Bit4
        RLY4 CON %0000100000000100 ' PORTD|Bit2
        ADCON1 = 7
        PORTA = 0 : PORTB = 0 : PORTC = 0 : PORTD = 0
        TRISA = 0 : TRISB = 0 : TRISC = 0 : TRISD = 0
    RelayOn macro
        movf  _x+1,w ; high byte = pointer to port file reg
        movwf FSR    ; load FSR
        movf  _x,w   ; low byte = port bit to change
        xorwf INDF,f ; toggle port pin
    RelayOff macro
        movf  _x,w   ; reload port pin to toggle
        xorwf INDF,f ; do it
        for i = 0 to 3
            LOOKUP2 i, [RLY1,RLY2,RLY3,RLY4], x ' lookup file reg & XOR pattern
            @ RelayOn
            PAUSE 500
            @ RelayOff
            PAUSE 500
        next i
    -Bruce
    tech at rentron.com
    http://www.rentron.com
    I agree, good stuff!
    Here's another one.
    INCLUDE "VirtualPort.bas"
    Relays  VAR BYTE : Relays = 0
    RelayPort  macro
        Vpin  0, PORTB, 6  ; RELAY1
        Vpin  1, PORTC, 4  ; RELAY2
        Vpin  2, PORTD, 2  ; RELAY3
      OutputPort  RelayPort    ; Set Port to OUTPUT
    Then, here's a test loop to cycle thru the relays...
    i  VAR BYTE
        for i = 0 to 2
            Relays = DCD i
            @  WritePort _Relays, RelayPort
            PAUSE 500
        next i
    Goto Main
    Code size = 104 words, 65 without the PAUSE.
    or you can just...
    Relays = %010
    to turn on RELAY2 by itself.
    Code size = 21 words.
    http://www.pbpgroup.com/Vport/VirtualPort.bas.txt
    HTH,
    Last Post: - 14th June 2016, 08:55
  2. Simple Array Demo
    By Archangel in forum Code Examples
    Last Post: - 15th February 2010, 05:46
  3. Custom array of pins
    By bmagistro in forum mel PIC BASIC Pro
    Last Post: - 29th March 2009, 00:15
  4. Crystalfontz LCD
    By jman12 in forum mel PIC BASIC Pro
    Last Post: - 9th February 2007, 16:04
  5. Making Array of two ports
    By John7 in forum General
    Last Post: - 5th March 2005, 03:20
