problem with picall
Results 1 to 11 of 11
    Smile problem with picall
    No problem it works perfect, have a look at your ini file and see if its up to date any problems contact me, I'm using Picall for 5 years now and I think it's good. If you are using PBP then try this command line "$hex-filename$ -dpic$target-device$ -n -x -p" and you can compile and program with one click, provided ure chip is in the ZIF.
    Mar 2004
    Now using Melabs USB prorammer, works great easy to install, easy to use would recomend it to any one. Well wort the money.
    Thanks for the help
  1. Problem with ASM IRQ using FSR0 on PIC18F252
    By mytekcontrols in forum mel PIC BASIC Pro
    Last Post: - 11th March 2008, 20:48
  2. USART Problem , but don't know where, in pc? or in PIC?
    Last Post: - 15th July 2007, 08:12
  3. 1 slave 1 master 1 MAX232 1 problem ?
    Last Post: - 31st July 2005, 22:59
  4. weird 12F629/675 problem
    By peterdeco1 in forum mel PIC BASIC Pro
    Last Post: - 7th October 2004, 01:08
  5. PORTA.PinNo = 1 ' problem
    By frank small in forum mel PIC BASIC Pro
    Last Post: - 6th May 2004, 14:30
