I am instaling Picall on Windows Exstra Problems now for the first time, it was working well on Windows My Edition(ME) without any problems I will let you know if the problem is only with XP.
No problem it works perfect, have a look at your ini file and see if its up to date any problems contact me, I'm using Picall for 5 years now and I think it's good. If you are using PBP then try this command line "$hex-filename$ -dpic$target-device$ -n -x -p" and you can compile and program with one click, provided ure chip is in the ZIF.
Now using Melabs USB prorammer, works great easy to install, easy to use would recomend it to any one. Well wort the money.
Thanks for the help
