Signal in Sound out...
Results 1 to 12 of 12
    Question Connectors ...
    In my near family there is a Fiat diesel that used to cut the engine on the left lane of the highway ....
    time to stop, and it was ready to run ...
    Just a connector pin that was badly crimped ...
    I know ... lots of investigation to find it !!!
    You surely will spend a lot of time to build and test your auto computer. I thing that the electronics in the computer are the last to look for problems.
    I would suggest to spend an afternoon checking on all the electrical connections, sockets, cables that could stop the engine including spark plugs cabling (be careful, there are dangerous Voltages...). I am sure will will find it within a few hours (or minutes if lucky!).
    Apr 2006
    New Hampshire USA
    Smile My two cents!
    I had a compact car, that ran virtually without maintenance, for over 100 thousand miles.
    The only problem it ever had:
    Sometimes, the engine would "cut out" when I went fast around a traffic circle (round-about). When the engine lost all power the car would slow to almost a stop. Then, it would re-gain power and exit the circle. This happened without regard for weather. There was never any other engine problems.
    One day, I found there was a wire (harness) that had been moved, by a mechanic, early in the service schedule. An ignition wire was pulled by centrifugal force, to chafe on the engine. When the chaffing wore a bare spot through the insulation, the bare part would short out, each time the centrifugal force (round-about) would re-appear.
    Two cents worth of electrical tape, and back to flying around the traffic circles!
    Not that this is any help, I just like telling the story.
    -Adam-
    New Hampshire
    Default signal in... sound out : follow up
    I wanted to get back to all of you for your help and encouragement. I ran across a good website for mopar repairs and it seemed to point to several possible faulty sensors. The second sensor I replaced... the MAP sensor, did the job. The faulty MAP sensor was causing the stalling. It hasn't stalled since... over a week now. Thank God it wasn't a harness issue! Ye Gods and Little Fishes!
    CUDOS to schu4647. You were spot on!
    After years of stalling I have a van running peachie again. *dancing a little jig* (sorry you can't see that... :-)
    Again thanks to all.
    Ross
    Never enough knowledge to be called intelligent but just enough knowledge to be considered dangerous!
    I like that! :-)
    Apr 2006
    Michigan
    I don't really deal with the controls side of automotive, but I beleive once a vehicle gets warm it enters a closes system mode. Fuel delivery is then calculated by the engine computer based on the O2 Sensor and MAP sensor. A bad MAP sensor will cause the engine computer to decrease fuel which will cause it to stall. It is all a pain in the but, but it significantly improves fuel economy.
  1. Delayed output 10 secs
    By lilimike in forum mel PIC BASIC Pro
    Last Post: - 14th October 2011, 07:28
  2. PIC16F684 + LCD to use the 256bytes of EEPROM - HELP
    Last Post: - 7th March 2008, 15:19
  3. new to PIC programming could really do with some help
    By karenhornby in forum mel PIC BASIC Pro
    Last Post: - 5th March 2008, 15:03
  4. Help with sound command in 2 programs
    Last Post: - 5th July 2007, 21:36
  5. Sound and sound control with minimal parts
    By bartman in forum General
    Last Post: - 18th January 2005, 15:08
