7805 regulator + diode
Results 1 to 5 of 5
    Question 7805 regulator + diode
    Hello,
    I was wondering, do I need a diode protecting my circuit against a reverse polarity applied before the 7805 regulator?
    Or, can the 7805 regulator handle a reverse polarity error protecting the circuit attached to it?
    Thank you very much.
    Daniel.
    Oct 2003
    holland
    No, a 7805 is not a reverce polarity protector. A series diode at the input site of an 7805 is a good protection of reverce polarity. Don't forget the extra capacitors at the input and the output of the 7805.
    Jan 2006
    Istanbul
    Why don't you try?
    You can see the result with your own eyes; good or bad.
    Yes, I know I could have tried, but I didn't want to burn a good regulator by changing the polarity.
    Thanks!
    Sep 2005
    Dayton, Ohio
    Quote Originally Posted by sayzer
    Why don't you try?
    Use eye protection (safety glasses)!! ;-)
    Jim Robertson
    "MilesTag" DIY Lasertag
    www.lasertagparts.com/mtdesign.htm
    Dayton, Ohio
  1. Better Alternatives to 7805 ?
    By Art in forum General
    Last Post: - 21st December 2009, 10:21
  2. 24VAC Transformer from Air Handler, 7805
    By nemesis in forum Schematics
    Last Post: - 25th February 2009, 20:23
  3. 7805 works fine, LM2940CT5 not!
    By DanPBP in forum Off Topic
    Last Post: - 29th August 2007, 23:01
  4. LCD backlight overheats 7805
    By RYTECH in forum Schematics
    Last Post: - 13th July 2007, 00:01
  5. 7805 heating
    By sirvo in forum Off Topic
    Last Post: - 9th February 2007, 23:16
