Data tables again !
Results 1 to 11 of 11
    malc-c's Avatar
    malc-c Guest
    Default Data tables again !
    In a previous thread I was advised to use an array to generate a pattern sequence to be displayed on portB of an 16f628a PIC (var i, D and pat1 previously defined)
    pattern3:
    pat1[0]=129
    pat1[1]=66
    pat1[2]=36
    pat1[3]=24
    pat1[4]=36
    pat1[5]=66
    pat1[6]=129
    pat1[7]=0
    For i =0 to 7
    portb=pat1[i]
    pause d
    next i
    However while this will work, I thought that a better idea would be to store the patterns in the PIC using the DATA statement, and I have generated the following patterns sequence (each number is a step in the sequence)
    patt1 data 16,1,2,4,8,16,32,64,128,128,64,32,16,8,4,2,1
    patt2 data 8,129,66,36,24,24,36,66,129
    patt3 data 16,1,3,2,6,4,12,8,24,16,48,32,96,64,192,128,0
    patt4 data 16,1,128,2,64,4,32,8,16,8,32,4,64,2,128,1,0
    patt5 data 12,24,60,126,255,231,195,129,0,129,195,231,255
    patt6 data 13,1,2,4,8,17,34,68,136,16,32,64,128,0
    patt7 data 8,128,64,32,16,8,4,2,1
    So in the above example, Patt2 would run the sequence from 8 to 129 over and over again until the selection switches are pressed.
    However I have two problems.
    1) - Being a newbie, I can't see how I can use the read statement to read back the sequence and send it to the port. I did think about using an array, so that each number in thye sequence is placed in the array like the following
    pattern[0]=8
    pattern[1]=129
    etc
    2) - As you can see each sequence is not the same length and thus defining the length of the array becomes complicated ?? I assume I could place a digit or some form of marker to signify the end of sequence, but then I would need to count the digits in the data "string" and then set the array length to equal the count, and I'm not sure how to do this, or if its the correct way. Advice please
    Here's several options.
    http://www.pbpgroup.com/modules/wfse...p?articleid=10
    http://www.microengineeringlabs.com/...bp/strtblx.bas
    http://www.picbasic.co.uk/forum/show...bedded+strings
    The first link to Darrel Taylors example is one of the best.
    The 2nd link is to one from MeLabs.
    The 3rd is an old thread on Embedded Strings in Code Space.
    It's a bit more advanced than the first two, but shows a ton
    of other options.
    -Bruce
    tech at rentron.com
    http://www.rentron.com
    May 2006
    Del Rio, TX, USA
    Malcom,
    Here is something you might be able to try. Add as the first data item in each pattern the number of items in the sequence (I counted quick, so there might be a mistake in the values I added)
    patt1 data 17,16,1,2,4,8,16,32,64,128,128,64,32,16,8,4,2,1
    patt2 data 9,8,129,66,36,24,24,36,66,129
    patt3 data 17,16,1,3,2,6,4,12,8,24,16,48,32,96,64,192,128,0
    patt4 data 17,16,1,128,2,64,4,32,8,16,8,32,4,64,2,128,1,0
    patt5 data 13,12,24,60,126,255,231,195,129,0,129,195,231,255
    patt6 data 14,13,1,2,4,8,17,34,68,136,16,32,64,128,0
    patt7 data 9,8,128,64,32,16,8,4,2,1
    Then use the something like the following to get the actual data:
    steps VAR BYTE
    counts VAR BYTE
    temp VAR BYTE
    READ Patt1, steps
    FOR counts = 1 TO steps
         READ (Patt1 + counts), temp
         PORTB = temp
    NEXT counts
    This should allow you to sequence through each step for the various patterns, regardless of size. You could then loop back and start the FOR..NEXT loop again if required. Or, move on to some other code, or a different pattern. Also, inside the FOR..NEXT loop you could insert any code you needed. Test for various conditions, and even break out of the loop if needed to move on.
    NOTE: I have not tested the actual code, as it is ment to be just quick example to get across my idea, So don't cut and paste it. Try to understand the CONCEPT presented.
    malc-c's Avatar
    malc-c Guest
    Steve, thanks for the reply,
    I agree its the concept that I couldn't get my head round, and your code will make a good grounding for some trials. It all seems so logical now, but last night after a long day my brain went blank
    Bruce, thanks also for replying, and I'll study those links in depth a little later (have work to do now )
    malc-c's Avatar
    malc-c Guest
    Default getting there, but still puzzled
    Steve,
    I took your concepte and I'm getting somewhere, but I've hit a problem which I can't figure out.
    The manual provides the following information when using the DATA statement
    {Label} DATA {@Location,}Constant{,Constant...}
    If the optional Location value is omitted, the first DATA
    statement starts storing at address 0 and subsequent statements store
    at the following locations.
    so I followed the format and used patt1, patt2 etc as the lable and ommitted the address, thus causing patt1 to sit at address 0 by default. The manual then gives an example of how to store three numbers in the EEPROM memory
    Store 10, 20 and 30 starting at location 4
    DATA @4,10,20,30
    Ok as I've used the default address and ommited the location my data statement looks like:
    patt1 DATA 17,16,1,2,4,8,16,32,64,128,128,64,32,16,8,4,2,1
    which also includes the number of steps as the first digit as suggested
    So far so good.... moving on to the READ statement the manual states
    READ Address,Var
    Read a byte from the on-chip EEPROM at the specified Address and
    stores the result in Var.
    Using your concept code the program fell over when it encountered the line "READ Patt1, steps" so logic suggested that its looking for a location rather than the lable patt1. so I changed the patt1 to read "READ 4, steps" and that compiled OK.
    Now the part that is confusing me is how to read back all the values in the data statement. It would be nice if the manual used the same example in the READ statement that it featued in the DATA statenment showing how to get back the digits 10, 20, 30. If I used your concept of "READ patt1 + count" with the correct syntax it gives
    READ (0+1), temp
    However would this then read the first byte of the DATA statement at the next address, as it would be interpreted as READ 1, temp... READ 2,temp etc or is the next address (1) be the next byte in the same DATA statement. If so I would then need to know the exact address for the start of the second DATA statement, and the Third etc
    Also do I need to use hexdecimal for address locations, or can I stick to decimal, so that the second DATA statement would thus start at address 18
    I'm now totally confused ??
    With regards to Bruce's post, a lot of that was in assemble, and at my current level of understanding with Pics and PBP I would much rather stick with PBP.. which is a steep enough learning curve as it is, without having to get my head round asm code !
    Feb 2003
    Salt Lake City, Utah USA
    Smile more ideas like SteveB's
    Coincidently in your first post, the first number you have in each row appears to be the count of the following bytes of data. i.e., it looks like this data already has SteveB's suggestion built in? I will assume it does – if it does not, add it in like Steve suggested.
    What PIC are you using? If you are using the 16F628, which has 128 bytes of EEPROM you could do something like this (although a tad wasteful).
    ;patt1
    Data @0, 16,1,2,4,8,16,32,64,128,128,64,32,16,8,4,2,1
    ;patt2
    Data @20, 8,129,66,36,24,24,36,66,129
    ;patt3
    Data @40, 16,1,3,2,6,4,12,8,24,16,48,32,96,64,192,128,0
    ;patt4
    Data @60, 16,1,128,2,64,4,32,8,16,8,32,4,64,2,128,1,0
    etc.
    ;The data could be found and read as follows (for patt3 for example)
    patt VAR BYTE ; pattern of interest
    EEadr VAR BYTE ; EEPROM address
    dataloop VAR BYTE ; number of data bytes (SteveB's suggestion)
    pattern VAR BYTE[20]
    i var byte ; temp counter
    patt = 3; want to get pattern 3 from EEPROM for example
    EEadr = 20*(patt-1) ; = 40, patt1 would be at 0, patt 4 would be at 60, etc.
    Read EEadr, dataloop ; find out how many data bytes to follow
    if dataloop > 19 then error ; can't have more than 19 or goes into next patt area
    FOR x = 1 TO dataloop
    EEadr = EEadr + 1
    READ EEadr, pattern[x]
    next x
    Do something with numbers here
    error:
    Paul Borgmeier
    USA
    May 2006
    Del Rio, TX, USA
    Question
    Malcom
    Quote Originally Posted by malc-c
    Exactly what didn't work? I actually did cut and paste this exact code and compiled based on a 16F877A:
    steps VAR BYTE
    counts VAR BYTE
    temp VAR BYTE
    READ Patt1, steps
         PORTB = temp
    NEXT counts
    And it compiled just fine. I just haven't programmed it into a pic to see what happens.
    Additionally, in reference to the following items:
    READ Address,Var
    When using the DATA command with a {label}, what is being done by PBP is the label becomes a constant with a vaule equal to the Address. So there should not be any reason that the read command does not recognized the label as a valid Address.
    Possibly posting you actual code and which PIC your using could help us puzzle this out for you. Also, the exact error/warning message you get when it compiles will also help.
    SteveB's code is exactly what you're looking for. You can make it even
    smaller/faster by reading each value in the list directly onto the port.
    Run this to see how it works.
        Patt1 data 8,1,2,4,8,16,32,64,128
        Patt2 data 8,128,64,32,16,8,4,2,1
        steps VAR BYTE
        counts VAR BYTE
        temp VAR BYTE
        TRISB = 0
    MAIN:
        READ Patt1, steps    ' get number of EEPROM entries
         READ (Patt1+counts), PORTB
         PAUSE 50
        NEXT counts
        ' now cycle LED's back the other way
        READ Patt2, steps    ' get number of EEPROM entries
         READ (Patt2+counts), PORTB
         PAUSE 50
        NEXT counts
        GOTO MAIN
    When you give each line a label you can just reference the label name to find
    the starting point or base address of each pattern in EEPROM.
    Patt1 starts at the first available location in EEPROM. Patt2 starts at the next
    available location after the last byte in Patt1.
    You don't need to know the physical address of each pattern because each
    one has already been assigned a label. Each label is a pointer to the base
    address of each separate pattern in EEPROM.
    -Bruce
    tech at rentron.com
  1. Using Nokia LCD
    Last Post: - 3rd May 2018, 04:47
  2. Nokia 3310 display text
    Last Post: - 26th August 2007, 03:39
  3. Big characters on HD44780 4x20
    Last Post: - 7th January 2007, 02:21
  4. LCD + bar graph
    Last Post: - 5th October 2005, 14:50
  5. Sinus calculating !
    Last Post: - 28th November 2004, 23:56
