Brushless DC Motors
Results 1 to 6 of 6
    Patrick's Avatar
    Patrick Guest
    Question Brushless DC Motors
    Is there anyone that have experimented with the above and is there a easy way to control these with PBP I know that PWM on some Pic is available but there is dedicated IC for the above like the st7mc1 which also does the control by measiring the non switch coil for position sensing.This can also be done with a resolver or Hall swithing.
    Anyone some idee.
    Patrick
    Jan 2006
    Istanbul
    here it is.
    http://www.picbasic.co.uk/forum/showthread.php?t=3299
    Mar 2005
    Default Brushless DC Motors
    Hello Patrick,
    Very easy to use are the MC33033 or MC33035.
    I used them succesfully in a couple of designs. For the FET's I Used the FDS8958 (Farnell), N- and P- FET in one housing.
    For the input use the Hpwm combined with a resistor and a capacitor. (Speed control)
    For the feedback just use the signals from the hall sensors who are availble on the MC330XX chip.
    Greetings
    Paul
    Talking Brushless DC Motors
    A Brushless DC Motor is a 3 phase AC motor with an inverter to convert the DC to 3 phase AC so you have to generate a 3 phase signal with the PIC, you can use a R2R resistor pack to generate a sine wave and 3 transistors to do the phase shift switching of your generated sine wave
    Lightbulb
    Quote Originally Posted by Patrick View Post
    Anyone some idee.
    Patrick
    Hi, Patrick
    just have a look to relevant Microchip AN's ... not PbP written, but interesting !
    Hangover, Germany
    Smile
    I've written such a controller in PBP, but the timecritical parts are in assembler (hall-sensors).
    The main questions are:
    What is the power of the motor ? Current and Voltage ?
    Are there hallsensors for the feedback ?
    How many rotations are required ?
  1. DC to servo pulse converter
    By Agent36 in forum General
    Last Post: - 16th December 2009, 07:09
  2. Replies: 24
    Last Post: - 1st December 2009, 09:01
  3. Current flow controller for DC Motors
    By mikebar in forum Schematics
    Last Post: - 28th March 2009, 18:23
  4. Problems with DC motors
    By Armando Herjim in forum Off Topic
    Last Post: - 9th August 2006, 09:09
  5. DC Brushless Motor controller?
    By forgie in forum Off Topic
    Last Post: - 4th February 2006, 15:02
