Obdii Vpw
Results 1 to 24 of 24
Thread: Obdii Vpw
    Apr 2006
    Michigan
    I think this might help a lot. I am looking through a J1850 book and it shows a few examples. They use a HIP7010 or HIP7030A2 as the handler. This should take care of the protocol aspect. Hook it into a HIP7020 Transceiver and you should be good to go. I didn't study the data sheet too much, but I think this will simplify things. Here is a link to the data sheet for one of the handlers.
    http://www.intersil.com/data/fn/fn3644.pdf
    Jun 2005
    Wisconsin
    One Problem:
    http://www.intersil.com/support/ps.a...r=HIP7010&R1=B
    HIP7010B=Retired
    HIP7010B96=Retired
    HIP7010P=Retired
    Discontinued, this has been the case for all the ICs that peform this type of function. I even checked Motorola/Freescale, they used to make chips similar to the above. However they have moved these functions onto their microcontrollers and discontinued the outboard chips.
    Apr 2006
    Michigan
    That wipes me out of ideas. I guess PIC's have limitations.
    Jun 2005
    Wisconsin
    Jun 2005
    Wisconsin
    After looking this over I think the inbound vpw could be read by either looking at the pin state and comparing it with Timer1 or using the CCP module and having this occur in the background. I have determined that Pulsin would be too slow to grab the whole packet.
    I'm kind of leaning toward the CCP module after reading the following.
    http://ww1.microchip.com/downloads/e...Doc/41215B.pdf
    (see tip #3 and #4)
    The problem is I have never used the CCP module before. Anyone have any experience with it? Advantages/Disadvantages to CCP versus Pin State/Timer1?
    Examples might be helpful.
    Wink a simpler approach ...
    Hi, Ben
    as your injectors and odometer wiring are accessible, may be it would be simpler to take the infos at the very source ...
    I remember Elektor magazine committed such a project ( in analog mode ...) 10 or 15 years ago ... If you want, I dig into my old papers ...
    I crossed it some weeks ago ...
    PS: from circuit cellar source, It would be much better to re-build the project from the C files downloaded ...ohhhhh, yeah , here it's PbP World ... sorry !!!
    Jun 2005
    Wisconsin
    Acetronics, you’re missing the point. I'm interested in creating code to read and write to the vpw buss. (I can't stress that enough) I'm not interested in a work around or using the off the shelf code from the circuit cellar project.
    I have used the ELM devices in numerous projects and am now looking into bypassing this device and putting the pic directly on the buss.
  1. Obdii
    By Smart in forum mel PIC BASIC Pro
    Last Post: - 1st June 2005, 03:15
  2. OBDII monitor basic code
    By droptail in forum mel PIC BASIC Pro
    Last Post: - 1st June 2005, 03:11
