Alarming problem
Results 1 to 17 of 17
    Early1's Avatar
    Early1 Guest
    Thanks Guys
    I have come to the conclusion that faster is not necessarily better. I have read and re-read the 18F452 data sheet and my impression is that at 40Mhz I should be using a higher baud rate but years of using GSM modems at 9600 has taught me that this is a safe reliable connection speed.
    Bruce I have ordered a 20Mhz Flash Lab and in due course all will be revealed.
    Cheers
    Early1's Avatar
    Early1 Guest
    Gents
    The 20Mhz Flash Lab does not work either.
    Hmmmmm.
    I can make it work, and the 40Mhz also, by entering the telephone number into the HSEROUT instruction.
    HSEROUT[34,"0123456789",34,13]
    but the way I want it to work and the way it did work was by using a string variable.
    HSEROUT[34,STR TelephoneNo\16,34]
    The reason I need it to work this way is because a keypad is used to enter or change the telephone numbers to text and also to store them in the onboard EEPROM.
    The real curiosity to me is that both of the above instruction work when connected to hyperterminal.
    I have upgraded to the latest version of PBP.
    This is all very curious.
    Has your string TelephoneNo been converted to ASCII first?
    Except for the first example being terminated with CR, ASCII conversion
    handled in-line, and the number of digits dialed, it looks like both should
    work the same.
    Does something like his work?
    STRING VAR BYTE[6]
    X VAR BYTE
    MAIN:
        FOR X = 0 TO 5
        STRING[X] = X + "0" ' convert digits to ASCII
        NEXT X
        HSEROUT [34,STR STRING\6,34]
    DONE:
        GOTO DONE
    -Bruce
    tech at rentron.com
    http://www.rentron.com
    Early1's Avatar
    Early1 Guest
    Hi Bruce
    No I have never included ASCII conversion and yes previously both did work the same. Curious is it not!!
    and even more curious is the way that they do both work when connected to hyperterminal.
    I will do some more testing tomorrow.
    Maybe I need to set the modem to ATE0.
    Early1's Avatar
    Early1 Guest
    Here is some test code.
    define OSC 20 ' set the correct speed here!!
    define LOADER_USED 1
    define HSER_RCSTA 90h
    DEFINE HSER_TXSTA 20h
    DEFINE HSER_BAUD 9600
    DEFINE HSER_SPBRG 32
    DEFINE HSER_CLROERR 1
    Teladd var byte
    TelephoneNo1 var byte[16]
    For Teladd = 0 To 15 ' Read Telephone number in memory
    Read Teladd,TelephoneNo1[Teladd]
    Next TelAdd
    sms:
    'THIS WORKS
    hserOUT [65,84,13] 'Sending "AT" and Carraige return to GSM module
    hserin 5000, SMS,[WAIT("OK")] ' wait for response ok for 5 seconds
    hserOUT ["AT+CMGS=",34,"07771716175",34,13] 'Here the GSM module is told the desitnation phone number
    hserin 15000,SMS,[WAIT(62)]
    hserOUT ["WJ Groundwater Limited One Pump Failed",26]
    hserin 15000,SMS,[WAIT(43,67,77,71)]
    'AND THIS DOES NOT
    hserOUT ["AT+CMGS=",34,str TelephoneNo1\16,34,13] 'Here the GSM module is told the desitnation phone number
    serout portc.5,6,[12, "msg SENT"]
    The version that works is sending an 11 digit phone number. The version that
    doesn't is sending a 16 digit number that may or may not be in ASCII format.
    Does this work?
       X VAR BYTE
       Y VAR BYTE
        FOR X = 0 TO 10    ' 11 digit phone #
          LOOKUP X,["07771716175"],Y
          TelephoneNo1[X] = Y
        NEXT X
       hserOUT ["AT+CMGS=",34,str TelephoneNo1\11,34,13] 'Here the GSMmodule is told the desitnation phone number
    -Bruce
    tech at rentron.com
    Early1's Avatar
    Early1 Guest
    Hi Bruce
    A couple of very good points you have made there.
    I had the same qeries when I originaly wrote the program.
    The telephone numbers are stored on the eprom and non digits are padded out with nulls so
    012345678912 in the eprom looks like
    012345678912______ where _ is null or 0 in hex
    the program then loads this data into the telephone variable and when viewed in ICD mode looks like
    48
    49
    50
    51
    52
    53
    54
    55
    56
    57
    49
    50
    0
    0
    0
    0
    0
    Now what happens is that when I use the hserout str function it automaticaly detects the first null and concatinates to 012345678912
    and looks like this in hyperterminal AT+CMGS="012345678912"
    I was well impressed when it worked, over the moon sort of thing and it was the easiest of many issues to solve. I2C master and slave mode were the hardest by the way.
    But this time it does not work.
    I will try your suggestions.
    I believe that we are foucusing in on the root cause of the issue.
  1. Problem with ASM IRQ using FSR0 on PIC18F252
    By mytekcontrols in forum mel PIC BASIC Pro
    Last Post: - 11th March 2008, 21:48
  2. USART Problem , but don't know where, in pc? or in PIC?
  3. Microcode Studio 18f2455 problem?????
    By volkan in forum mel PIC BASIC Pro
    Last Post: - 21st May 2007, 22:04
  4. Hardware problem or what ?
    By Steve S. in forum mel PIC BASIC Pro
    Last Post: - 4th March 2007, 22:39
  5. 1 slave 1 master 1 MAX232 1 problem ?
    Last Post: - 31st July 2005, 23:59
